So I’m looking to paint my brake calipers in blue and I’ve been looking at high temp paints and also primers and gloss topcoats anyone know best techniques to go about this? Or any tips you may have
Unless you paint the calipers green, then it's OK. Might as well go ahead and paint the tires green too, just to be safe.I am of the opinion that when you paint your calipers, the eyes of others goes to that bright spot hiding behind your wheel, and not to the driver. You want the car to look sharp so the ladies submit to your desires?
Keep it clean and don't spend time modding or harping on about it as she'll (he'll) think you care more about an appliance than her/him/they/? (What happens in fanatics stays in fanatics.)
How is your car otherwise in terms of being maintained?
How many coats of paint did you use? I think part of the issue I had with the rears was that I didn't go heavy enough or put on enough coats. I dusted on 2 light coats to start just to get coverage, and 2 more medium/wet coats. From what've read the more coats the better to build up a hard candy shell.I bead blasted and painted my calipers when I upgraded to 330i brakes ~two years ago now. Unlike Mark I recommend it, mine still look great.
If the calipers are rusty enough that you want to bead blast them then the factory zinc coating has already failed.
I used VHT silver caliper paint without primer. Pretty sure all of the caliper paints are meant to be applied to bare metal.
Because of electronic parking brake you can't even get multi piston caliper on new M3, M4 and even M8. You pay >$100K (make that >$200K in my country) for sh*t color rusted rears after two rains. Personally I'm over it.IMO the only calipers that should be painted are the multi-piston fixed type, but it's your car...
