Alternator options?
2 reading
5.2K views 11 replies 4 participants last post by  Mr.Miller
#1 ·
Hello forum
I have a 03 m3 with a Valeo alternator rated at 120 amps and I think my stereo has finally beat it up
When I ran the voltage test on the OBC I had 13.6 volts resting,13.9 driving with nothing on,around 13.6 with lights and ac and with the stereo up I could beat it down to 12.4
The battery is about a year old so I swapped it it with a new yellow top I had and the results were about the same
Does anyone make a higher amperage Valeo alternator?
I've seen higher output Bosch units,are they direct bolt ins with a pulley change?
If so where and what pulley do I need?
Has anyone had any experience with the rebuilt Bosch or Valeo alternators on eBay ?
Thanks for any input
#8 ·
I was just looking up the specs on my amps and my 4 channel draws 60amps max @13.8 volts and suggest a 75 amp alternator and my 2 channel draws 80amps max @13.8 volts and also suggest a 75 amp alternator (which doesn't make sense)
So by the spec sheet that would be 140 amps max but I run my amps turned down about 75% and that's just on paper not actual gauge readings
#10 ·
Those current draws will be at continuous full power (volume) from all channels. As the volume comes off max or the signal changes from continuous tones the current draw will reduce. With music there will be high peak currents that may reach those quoted figures but the average current which is what matters to your charging system. How they suggest alternator sizes is quite subjective as the inconsistent recommendations show.
I ran a system (4*150W & 1*1000W RMS) without any trouble although it's not a good idea to use it for extended periods without the motor running.
For now I'd just make sure your charging system is doing its job before upgrading the alternator.
