Air Intake Foam Gasket for 13717501974
1 reading
7.8K views 10 replies 6 participants last post by  paraklas
#1 · (Edited)
I found the answer after further searching. According to an ECS Tuning picture, the foam gasket comes with 13717501974.
Many thanks.
#2 ·
What is the purpose of that foam price. The one on my car was shredded and dusty beyond belief. So I just pulled it out and threw it away. The only purpose that I can imagine is to prevent any rattle between that tiny intake scoop and where it wedges in between the headlight andthe expansion tank. Can't imagine it serving any other purpose.
#3 ·
My guess is also that it is just to prevent vibration.
The whole part is only $7 to $9 depending on where you buy it. Next time I am ordering something else, I may add one to my parts order and change it out the next time I have to pull the air filter box. Probably not worth the cost of shipping to order it separately and certainly not the inflated prices that my nearby dealer would charge for it.
#6 ·
I was wondering about that a few months ago but never bothered to search for it, so thanks for the part number.
However, I'm temporarily running my stock intake again and just tossed the foam since it was torn up. Doesn't make a difference with it gone from what I've observed. There is no rattle either at idle or under load, and as long as the bolts holding the intake are tight and the clips for the air inlet aren't damaged, I don't see an issue driving without it.
