I got the trio of DSC, red brake and yellow ABS lights on the dash mid-last week on a cold startup.
Brake fluid level fine and car drives and brakes normally.
I cleaned both wheel speed sensors (the right rear one was pretty gunked up) and reinstalled, no change.
Pulled codes via PA Soft, and I got:
- 17FE Error number 17FE (very helpful description there PA Soft
- 5DF5 Control Unit Internal Error
Safe to assume my DSC module has crapped the bed?
If so, the plan at this point is to pull one from a junkyard E46 (RealOEM says they're interchangeable between all the models), install and code it to the car. Looks like I'll have to install INPA/NCS Expert for that last part. I'm uneasy with the coding side of things (not an IT pro so it's not "natural" for me) but all the resources online really make a difference. :thumbsup:
