320 Ci: Previous owner rear shock cock up causing DSC issues?
1.7K views 6 replies 3 participants last post by  dorgasm
#1 ·
So, just took my 320 Ci through the NCT (Irish National Car Test) and all was fine apart from the rear suspension, which failed. Nearside 57mm, Offside 175mm. This gives a whopping 67% imbalance (30% being the cut off).
The guy who tested the car told me he suspects that two different sized shocks have been installed on either side of the car and that's what's causing the imbalance (maybe one regular suspension shock, one original sport shock?). Any opinions on whether this would this be the most likely cause of such a large imbalance? I have new sports shocks and mounts arriving tomorrow and I'll be changing them this weekend so I'll be able to check for certain then anyway.
The real issue I'd like an opinion on is the regular appearance of my DSC and handbrake lights. Now, I think the two are possibly related. If there is such a large imbalance, would the wheels be spinning at slightly different speeds and could this be throwing off the data being provided to the DSC module by the wheel speed sensors, thus making the DSC light come on? I'm not sure if I'm completely wrong about this but I'd like to hear if anyone has any thoughts on this possibility. Cheers!
#4 ·
oh I was going to say broken coil spring as well. but that's the shock travel difference.
i don't see how it would make the wheel turn more or less. but i'm thinking it could cause the "yaw" sensor to be off, thus triggering the DSC :dunno:
#5 · (Edited)
I was also thinking yaw sensor/steering angle sensor, but I reeeeally hope it's not. I've gone through the DIY here for it several times and I think it might be a DIY just out of my comfort zone. Haven't seen any surefire way of diagnosing whether it's the SAS so I'm hesitant to buy the part or take the steering column apart.
My thinking behind the wheel speeds being different is a stretch I'll admit. I was thinking that since its intermittent and since our roads are lumpy and rarely smooth, it would have some bearing in how the wheels are travelling and providing data to the DSC. I'm no expert anyway, just thought I'd propose the theory!
#6 ·
wasn't thinking the yaw sensor was bad. just being trigger by uneven side heights. sort of like the car sitting as if it's on an off camber banked turn. but driving straight. :dunno: purely just a theory I'm mentioning to examine. guess we will find out more when rear shocks are replaced and see how sensors react.
