318i to 320i swap (N42 to M54) - Mismatched connectors?
1 reading
60K views 88 replies 22 participants last post by  TeamClaymore
#1 ·
Hi all,
After my 2003 318i manual (presumably) blew the head gasket, i decided i had enough of that motor and began to swap an M54 in.
Everything went relatively smoothly so far, i got the wiring loom with the new engine and everything plugged in nicely, until i noticed two connectors in the DME box that didn't quite match up.
After a bit of research i've found that those connectors are X6011 and X6021:
934506
Now, the N42 engine most likely had the Bosch ME9.2 Motor electronics, while the M54 has a MS43 DME.
Using that, i've found the following Information on the BMW WDS app:
934507
934508
So, 5 incompatible connections. Due to X6021 Port 1, it seems like the car won't even start. I don't even have all the parts yet, so i have some time, but i don't know where to continue here.
My assumptions are:
X6011 Port 4 and 5 possibly don't matter, since they only connect to the instrument panel. I don't think they will prevent the car from functioning properly.
X6011 Port 8 is only the AC Compressor switch, and i can manually wire that in, so it's irrelevant. It connects directly to the physical compressor connection.
X6011 Port 2 is probably important, but i can't seem to confirm its function. If it doesn't prevent the car from starting, it might prevent OBD2 communication. But, how did the old ecu communicate? It didn't have that port, so it must have communicated somewhere else.
X6021 Port 1 seems very important, and will probably prevent the car from starting? Since the N42 had the connection and the M54 does not, it must be connected somewhere else, but i can't tell where.
X6021 Port 2 might be compatible, however i can't confirm it since it does go to a different connection. I was not able to tell from the WDS.
Does anyone have experience with these Connectors or this swap and can confirm/deny any of my assumptions? I'd be really thankful for help!
I have not yet started the car since i'm missing some more parts. If i can't make any progress till wednesday, i'll just try and see what happens.
#2 ·
When doing engine swaps, yes, you track down what each pin is, and then start moving wires to where they need to be.
Sometimes you have to go through multiple connectors, at which point, yeah, it becomes easier to
wire around the discrepancy rather than chase it through various routing. You need to be
careful to confirm that no- one gets kicked off the island when you do that, though, as often a signal's
routed differently because it's also going to a third destination as it makes that roundabout trip.
What gets involved is that you may then end up having to change other components, and re- pinning their connectors
as well. Have you confirmed that the N42 dash is the same as the M54?
With the E46, BMW was on their way to making discrete electronic assemblies interchangable, but had not
yet fully succeeded.
For example, can you find an oil level input on the dash connectors? Frustratingly, the labels aren't
always explanatory or consistent- often, you're left tracing out the wires on the corresponding diagrams...
Repinning the connectors isn't too hard- you just need to decide on which side you want to do it
(do you make your body harnesses M54 pinning (recommended) or do you make an 'adaptor harness'
to stick an M54 into an N42 body)
You're on the right track, keep at it!
t
#3 ·
Thank you, i've tried to be thorough while preparing for the swap, but didn't expect to stumble upon issues like this. It was never supposed to go smoothly, this is a learning experience for me.
I've managed to decode a bit more of the number soup that is the WDS: Apparently, both fuse 29 and fuse 30 of the N42 X6021 port 1 and the M54 X6011 port 2 end up at the S2 Ignition switch, they're both getting power at the same time. Thus i've decided simply move the M54 X6011 port 2 into the first port in the X6021 connector. The only difference is that Fuse 29 is 7.5 amps, and Fuse 30 is 5 Amps. If it doesn't work, replacing Fuse 30 with a 7.5 amp one should do the trick.
Downstream, it just connects to one of the DME connectors, as does the M54 X6021 port 2, so that should be fully compatible. The only differences now are the connectors going to the instrument panel. I couldn't find specific differences in the WDS, so i'll just try to run the engine without these two connectors and see what happens. I'll update as soon as the rest of my parts arrive.
#4 ·
Update!
I soldered the M54's X6011 pin 2 to the X6021 pin 1 on the car.
Started the engine for the first time today and all seems well. Fuse 30 did not blow and i don't have any warning lights.
I did notice that the battery light on the dash that is supposed to indicate a failing alternator turns off while i'm still in key position 2 (before starting the engine). that indicates to me that the instrument panel does not know if the alternator is charging or not, as it is only supposed to turn off once the battery is being charged. That is probably due to the M54's X6011 pin 4 not being connected. The oil light seems to work however, and disappeared after the engine started. A probably unrelated problem is that the Secondary air pump does not turn on.
I hope this info is gonna be able to help out the 1 or 2 people that are crazy enough to do this swap.
Regarding wiring info, i can recommend bmwteka.com aswell as the "WDS for Android Free" app, those two helped me figure this out.
#5 ·
Started this exact project just over 2 weeks ago and your post is really helping me! Apparently the guy I bought the engine from, provided the incorrect transmission harness so now I'm just waiting for the correct one to arrive.
Did you do anything else than changing pin 2 from X6011 to pin 1 on X6021?
I have SAP delete, so the air pump not turning on, wont be an issue for me.
Is your AC, headlights, heating etc. all working?
Thank you!
#6 ·
I didn't do anything electrically except changing the two pins you mentioned. I didn't touch any fuses, relays or other pins, and the engine is still running just fine.
The sap pump fixed itself and everything else is working, except the AC compressor, which you will have to manually wire to X6011 pin 8, which is where the N42 had the compressor switch. I haven't done that yet, but I'm pretty sure if you do that, it'll work just fine.
Remember you need to bring the wire all the way from the compressor into the DME box yourself, as i believe the M54 engine harness does not have a plug for the compressor (at least mine didn't).
Good luck with your project, it's nice to hear this post is actually helping people.
#7 ·
I'm so glad to hear that! Was just about to pay 950€ to get this car shipped to an expert so he could sort out all the wiring. Now that I discovered, I had the wrong harness it all makes a lot more sense.
Will definitely be wiring the AC compressor so that works, but thats the smallest issue at the moment.
I really appreciate this post. Don't think anyone else in Denmark has done this exact swap so I was really exited when I discovered your post.
Thank you so much
#8 ·
One of the fantastic things about the E46 is that the wiring usually isn't all that complicated.
Another thing i did, which you probably already know though, is get the DME of the new engine and the EWS module/immobilizer of the old car coded together, so that the immobilizer actually lets the key start the engine. It shouldn't be too expensive, i found someone on ebay who i sent the car's EWS module, the new engine's DME and the car's key, and when i got them back it all worked first try. If you don't do that, the engine will not start.
#11 ·
The guy I was about to buy the transmission wiring harness from, apparently had the wrong one. Do you by any chance have pictures of the harness that goes down to the transmission and 02 sensors? Or can you confirm, its supposed to look exactly like this? I found these pictures online and those connectors seem to match my other harnesses perfectly.
#12 ·
Sadly i didn't take any pictures, but as far as i remember, on the manual transmission there was only one plug for the reverse lights switch, and then one each for the two O2 sensors at the bottom of the header+cat combo. The pictures you sent could work, as it has those, but it also has two more plugs which i can't identify. You'd need to check if your engine has anywhere to plug them
#13 ·
The pictures I sent would match my engine wiring harness perfectly.
The plug within the red circle, is the X6021 connection which is missing on the harness the guy sent me, aswell as the one I have now.
Do you know any websites in Germany or elsewhere in Europe, where I might be able to find this harness?
#18 ·
Yes thats exactly what we've done
As written above, you just need to rewire pin nr 2 from X6011 (green & brown wire in my case) to the empty spot on X6021.
Also make sure you have coded EWS to the new ECU if it itsn't coded out from the new ECU.
Im still waiting on the correct harness to arrive, but I'll be doing this exact thing in a few days.
Post an update if you get the engine started
#20 ·
I swapped from ME9 to MS43 (n42 to m54) and made sure i got transmission harness, engine harness and iginition harness for the m54 engine
Plugged everything in as normal and all I have to do, as I understand from "Cvariable", is to remove pin 2 from X6011 to pin 1 on X6021
I didn't touch any of the wires for the DME as you're doing
#21 ·
hi,
sorry to jump onto the post late but,
@FrederikBV
did you have the loom for the m54 engine, gearbox and ecu? was it literally just exchange 2 pins and all else was/will be fine? no major cutting and splicing into the existing loom on the 318? just asking as got a 320i m54b22 (rear end crash) and a 318i n42b20 (head gasket gone) and looking to make a start over the weekend, will have the engines and boxes swapped out in a day just the wiring side of things that i'm uncertain with.
cheers
#23 ·
Hey guys, sorry to not answer the last question. This thread has been invaluable in my swap too.
Done a m54b25 (2002 Facelift 325i) swap into a 318ci Vert (factory n42 manual). I've completed the above steps in the wiring successfully but I have one question. Has anyone transferred over an E box fan into the new car?
My 318ci didn't come with an ecu box fan and I'm wondering if I need it. And if I do, how to wire it up.
Cheers Legends.
#29 ·
Can somebody help me?, I have the same swap going on but with N46 and my DME/ECU is Bosch MEV9 and the connector for ecu is wayyy different than this N42 one. Im not an electrician so my head is fucking exploding since i can't figure out what to do, any help is appreciated.
And can someone tell me how to read the "X60001" etc. ty
