BMW AG Motorsport parts
Pictured here is the European S50B30 engine used in the BMW E36 M3 GT from 1995. Right away you will notice it has a different cylinder head than the USA S52 and note the individual throttle bodies for the intake manifold. I can tell you that BMW AG Motorsport division offers nothing for the USA spec S52B32 in way of factory race car parts. However I do know BMW AG Motorsport offers factory race car parts for the S50B30 and S50B32 race engines. The camshafts for the Euro S50B30 and S50B32 race engines are now categorized as P50 at the BMW AG Motorsport division. This helps separate the race spec from the street spec. I will list the different BMW AG Motorsport camshafts sizes. NOTE They are designed by BMW AG Motorsport division produced under some incredibly advanced design standards that consistently set them apart from the rest of the manufacturers. Please note for the record these are not and never have been SCHRICK. Schrick is not bad but when compared to the perfection standard at BMW AG Motorsport division in a race engine dyno test with identical engines they are always down by 25HP compared to the BMW factory built race spec version.
*********61 Einlassnockenwelle Inlet camshaft 264/7' S50B30GT
*********24 Auslassnockenwelle Outlet camshaft 260/1' S50B30
*********26 Einlassnockenwelle Inlet camshaft S50B30 260'
*********22 Einlassnockenwelle Inlet camshaft S50B32 260'
*********23 Auslassnockenwelle Outlet camshaft S50B32 260'
*********19 Einlassnockenwelle Inlet camshaft 288' S50B32
*********20 Auslassnockenwelle Outlet camshaft 272' S50B32
*********69 Auslassnockenwelle Outlet camshaft S50B30 272/2
*********74 Einlassnockenwelle Inlet camshaft S50B30 280/2
*********53 Einlassnockenwelle Inlet camshaft S50B30 284/1'
*********85 Stössel Cam follower d=37,5 h=6,11
*********38 Auslassventil Exhaust valve 30,5 7mm Na
*********27 Federteller unten LOWER SPRING POCKET S50B30+B32 Gr.A
*********51 Federteller oben Upper spring plate S50B30 Gr.A
*********58 Einlassventil Intake valve 35 /7 mm hohl
*********23 Ventilfeder Valve spring S50 Gr.A
If your trying to save money and build a race car, what are your race series rules and limitations? If its for the street, I believe someone mentioned supercharger kits for $5K that will be cost effective. Remember to restore your engine if its aging, the seals and gaskets will need replacing and always remember to get improved fuel injectors vs stock so you don't burn the pistons with a supercharger. I remember ESS has a nice setup, the only thing to make it even better would be a high performance fuel pump in the tank and stand alone ECU with Motorsport display and custom engine wiring harness but now your at $17K in parts without labor for street car enhanced fun. If you race get a dry sump system its worth every penny, saves money on rebuilds as well as assists with power deliver and consistency. If you don't have a dry sump it can knock the bearing out of the motor by dipping the oil, this can be done with some decent coil over adjustable suspension when cornering on the track at high speed. So get a dry sump, BMW AG Motorsport factory race engines big and small all have dry sumps.
