Hi all,
Sad story to begin with. I was on a highway doing about 95mph when a metal piece/ part of semi truck tire flew from underneath the pickup that was in front and hit my bumper,radiator and went underneath the car ripping apart the plastic shield and in the process took out the power steering line ( may be because of shock because the line that broke was the low pressure return line), fog lights and horn wires and ambient temperature sensor was missing obviously. My radiator lost all the coolant in under 20 seconds from the impact till i could park the car on the side ( which is such a pain without the power steering). I would like to mention that the engine did not overheat the needle merely went one notch over the center mark by the time i turned off the ignition.
So i started the repair work by replacing the radiator from one with a used junkyard part, upper and lower radiator hoses were replaced with new ones and i replaced the PS return hose with a standard PS hose with worm clamps. Also i would like to mention that water pump and thermostat are less than a month old ( WP is Rein and Thermostat is Wahler ), expansion tank is less than 6 months old. during this process i repaired the heater control valve which was not opening completely. i put everything back together and started the car and let it idle. it took about 5-10 min to get to operating temperature ( distilled water only no coolant i wanted to check for leaks) i believe it took longer time to get to operating temp because the outside temperature was 0 deg C. Also in the process i broke the gearbox thermostat for cooling so i ordered a new one but in completed the work without having one installed. but after getting to operating temperature the coolant temperature was holding rock steady at 95 deg C. even with a bit of fast driving about 50 miles of test driving the temperature did not go beyond 97 deg C.
So the next day i was on the highway again doing about 50 mph with a bit of traffic, all of a sudden the coolant light comes on and the temperature needle began to move and it took me about a minute to get to the side because of the stupid traffic and i could not go from the middle lane to the shoulder. by the time i stopped the needle hit the red. i popped the hood and smoke from the rear of engine and i knew blown head gasket with warped or cracked head. when i looked underneath the hose that connects at the bottom of the radiator under the expansion tank was popped out. anyway towed it back home. after the engine had cooled down i fixed the hose and poured distilled water in. kept the radiator cap open and cranked. the water shot straight up and exhaust was coming out of the expansion tank. so confirmed that i need a new head with new gaskets and i know i have to use time serts as well.
Any way i started to pull out the intake and it was a pain in the ass . i hope this thread helps anyone else that is going to take the intake manifold out. this m54 is so ****ing different than all the other engines in the DIY videos i see. for starters the wiring harness box attached to the intake is not a smaall single piece its a L shaped with a metal bracket holding 2 different boxes bolted using 5 bolts. 2 bolts are visible and accessible but the bottom 3 are not visible and needs to be removed using just the feel. the intake cannot be removed just by unbolting the bolts at the head. there are 2 more t25 holding the intake bolted to a support frame which is bolted in front of the starter which can only be seen after removing the butterfly throttle valve. there is no way to remove the bracket itself as there is no space to use any ratchet long enough to give the leverage to remove it. the t 25 are right above the plastic coolant line that goes to the expansion tank. so there is no room to fit even a 1/4 inch wrench with a socket. i used t25 bit with a 1/4 inch spanner and took the bolts out. and remember the bit can fall off. and once it falls its in some other dimension. i lost 2 bits. luckily i had 3 of them. it took me about 3 hours just to take the 2 bolts out. the intake manifold has the fuel line and the wiring harness for the coils and injectors attached to it at the back inside a plastic support which is bolted using a t25. this cannot be removed so i just broke these and took the harness and removed the fuel rail out. All this took me 2 days and finally the intake was out. and dont forget that the dipstick tube has the harness support bracket bolted to it as well. :banghead:
now i proceeded to remove the valve cover which was done in 10 min. i removed the SAP as well. easy no headache. i have the timing tool kit as well so i proceeded to remove the double vanos. so naturally i started to find the TDC using a long screw driver and tried to match the notch on the crank pulley to the TDC mark on the block. but my pulley does not have a notch it has 2 circular notch like marks which when aligned with the mark on the block none of the cylinders are at TDC. this is confirmed by the screwdriver and the camshafts ( the timing locking tool place is not flat and the first cam lobes are not pointing to each other ) so anyway i figured the pulley might be installed wrong and proceeded to lock the crank since i knew i was close to TDC after installing the camshafts locking tool. I found the hole on the bell and the hole in the flywheel i checked this by trying to insert a allen key rather than the lockin pin itself to make sure the pin will go in with a little bit of wiggling. strange thing is the hole on the bell is smaller than the locking pin. i tried to find the dimensions for the locking pin and its correct but the hole on my bell seems to be a tab bit smaller. i thought may be dirt and tried using brake cleaner to clean the hole no luck. :banghead:
i forgot to mention that this locking pin hole is visible only when i remove this canister that none of the videos i have seen has. it has a bracket bolted to block again hard to access ( i will kill the guy who designed this piece of ****). and it has 2 hoses one going into the cabin and the other connected to the intake.
so now i have stopped working and figured i come here to get some advice and tips and tricks from you guys. the Intake manifold is out valve cover is out and cams are locked in place at TDC ( i hope that this is the TDC took me 3 hrs to figure it out) timing tensioner on the side of the engine removed and replaced with the one in the timing tool kit. the top tensioner is pressed in and held in place with the pin. ( this top one needs to be pushed in multiple times to relieve oil pressure do not force it down, just keep pushing it down and releasing it a couple of times and you should be able to lock it in place.
i have removed the small plate like thing on top of the exhaust manifold that hides the ****ing bolts to remove the exhaust.
at this point i am too tired and frustrated to remove the exhaust manifold. i am just going to disconnect it at after the CATS and release them and try to remove the head with the exhaust manifold on. I am in no mood to lift the engine up by removing the engine mount and go underneath the car to remove the E-manifold. its ****ing cold in texas.
So i need to know if i can proceed to remove the head and timing components with the crank pin not in place. i figure the TDC i have is 99% correct.
any tips on removing the head with the E-manifold on ? anyone has any experience dealing with a 2004 330ci m54 engine ? its a september build i believe. there are a lot of minute yet stupid changes. And No mine is not a M56 SULEV its an M54 ULEV. it was first bought in texas and has stayed in here.
Also can i use the head from any 328/325 ? i cannot find any 330 in any junkyard in DFW area. but i did find a 2002 530i with m54 engine. can i use that head ? i know mine is either warped or cracked or both. i dont care. i am changing it any way. can i swap the timing components from my head to the 530 head or any of 325/328 head ?
any tips /tricks/ advices please help me. i hate this stupid rental car i am driving and want to get back in my Bimmer. And i do not want to do a complete engine change as well ( international student with no job. i am relying on my savings to fix this at home). the cheapest engine i could find was 1200$ and has 75k miles on it and its a 328. the 330 i found was 1800$ with 45k miles. i cannot afford them and i do not have the tools to do an engine change. :banghead:
i am going to assume that my block is good and just needs a new head with new gasket and timeserts. the car runs fine it starts and idles and drives too. No hydro lock while i tested to see if the engine was dead.
please help me.
i live in Arlington near DFW area. i can come and meet any gurus that might give me some tips or tricks.
FYI the car has 171K miles. i got it last july when it had 144K miles. never had any major issue. overheated once when the water pump seal broke and once when the expansion tank blew. but since i saw a cloud of steam i pulled over even before the needle would move to the 3/4th mark. and i have put in over 2500 miles since the last overheat when th WP gave up. no change in engine performance or whatsoever. loved the sound and i cannot wait to hear it again.
sorry for the long post but i had to explain my situation so that its easier to get help.
TIA
please help me.
TIA
