2.93 to 3.46 Differential (in a 328i)
49K views 60 replies 19 participants last post by  Duke W
#1 · (Edited)
I just got my 328i a couple weeks ago, and I'm already considering doing a few improvements to the performance aspect. My two main areas of concern currently are handling and acceleration. My last BMW was an E36 M3 and I really miss the feeling of going around turns on rails and the LSD.
I don't expect to ever achieve these to exact feelings my 328i, but I would like to make some improvements. I think that I'm going to focus on acceleration for now, and specifically on the differential. Due to a clunk when shifting I may have to replace my rear differential mount and I figured while I was there I may as well get something with a little more pep than my 2.93 stock final drive in my 5spd 328i. As I've read on the forums, the 3.46 seems to be the best deal as it can be found for about $200-$300. If there is anywhere to get an LSD for <$1000, someone please let me know, as I'd be all about it.
How much of a torque increase will I actually get over the stock 206ft/lbs? Is there a way to calculate the percentage increase... is it 18% (I tried figuring it out through some random method that I'm sure is wrong)?
Also, how necessary is it to get a chip when doing the differential upgrade? Does pretty much everyone do this, and is there any danger in bumping up to 7k RPM's?
Thanks for any help!
#2 ·
I just realized that the 206ft/lbs of torque is measured at the crank, so obviously it's a different ballgame at the wheels. Anyone know what all the e46's put down at the wheels, or how to calculate it (i.e. how much loss there is)? Thanks.
And I've already been looking at this site: http://www.bokchoys.com/differential/GearRatios.htm
#4 ·
It's not necessary to get software with a diff swap but it's definately beneficial. Raising redline from 6500 to 7000 will help make shifting a little more comfortable and alleviate the top end decrease due the shorter final drive.
As far as an LSD, you're going to find it hard, if not impossible, to find a one under $1000 being as though the only way to do it is a custom job.
#7 ·
I doubt you can find an limited slip unit for less than $1000 because you need to pay for the limited slip unit and the labor for it to be installed. The cheapest LSD you can get is the Qualife ones. As for the torque increase, you are right, it is about 18%. Good luck!
I have an LSD right now and the difference between a LSD and an open differential is so huge. Like you said, the LSD just makes the car hug the corner! If you want the best LSDs contact Jim Blanton at Performance Gearing. Excellent person to deal with! :thumbsup:
#8 ·
At the cost of getting an LSD for an E46 I'd rather just hold of until I buy an E46 M3 in a couple of years (still a poor college student afterall ;)).
#10 ·
slow323ci said:
Going from a 2.93 to a 3.46 is an 18% change. Will also raise all your revs by 18%. I would wager that 95% of people would find that much of an increase in revs unacceptable. Basically you wil make 1st gear almost useless and effectively turn your car into a 4-speed.
no doubt, i am in 1st gear for like a second before i am at 6500k, and i have to shift (5 spd, 3.46) you might be better off with a milder 3.15 or 3.07...
#13 ·
SpeedDemon said:
Isn't that the same gearing though in a 328i w/ a 3.46 as a 323cic/325cic?
If they came from the factory like that, then is it really that bad?
Well, the 3.46 came from the factory on 323 and 325 steptronic cars. We all know that steptronic slows the car a bit. :p As for first gear being useless, try being boosted. The revs fly even faster. I think a 3.46 is better suited for a 6-speed because for me at 80mph, I am at ~3k.
#17 ·
SpeedDemon said:
So does everyone here recommend that I stay away from 3.46? It seems like it's going to be real hard to find a 3.38.
I think for a 5-speed, you should stay with a 3.15. A 3.46 and 3.38 has less than 3% change. You will still be at about 3500 @ 80mph. If you don't cruise much, then the 3.46 is fine. But once you start doing lots of cruising, it would most likely reduce your gas mileage.
#18 ·
Ha ha no **** dude? I bought a 328i back in August and I had to replace my rear diff mount too. Son-of-a-*****. :)
#19 ·
Did it actually fix anything for you when you replaced the rear mount? Did you have a clunk before that?
I really don't think that I would mind doing 3500RPM at 80MPH. I actually don't do any long distance driving. The Bimmer is my daily driver for getting around the city. I usually try to own two cars so that I have another car for any long distance driving that I have to do... it's likely that I'll pick up an E30 or a Honda or something soon.
Can anyone with a 3.46 in a 328i or 330i actually tell me that they regret doing it?
#20 ·
It's hard to suggest which you'd like better. You say it's a daily driver..so leeds me to say 3.15..but you also are coming from an E36 M3 and say you want acceleration. Then I easily say 3.38. What size wheels you running and do you expect to swap them out in the future? If stock 16s, go 3.15. With the 3.15 you also won't be "craving" the software(Shark)download.
#21 ·
How poorly does it actually affect gas mileage? I have the stock 17" sport wheels; I run 225/45/17's. I plan on possibly getting some 18" or 19" CSL replicas one of these days, but I'm fine for the time being with the stock wheels.
I feel like the gears are really tall coming from the M3, but maybe I'm just imagining things. What would it take to get an 328i geared like an E36 M3?
Also, wouldn't I actually only be doing about 3658RPM's at 80MPH vs. the stock 3100RPM's. That's an 18% increase, but it doesn't seem that ridiculous to be doing that at 80MPH. Is this bad for the motor?
#23 ·
I was looking into the 3.46 diff swap for my 328 also, but changed my mind due to the fact that a) high RPMs, worse gas mileage b) constant shifting c) loss of cruising ability and d) loss of really high end speed.
I was thinking about going 3.38, but they are hard to find and cost a bit more. Also, it isn't that much of a difference over the 3.38.
I recently read about someone installing a 3.23 diff in their car and am in the process of finding one. If that doesn't pan out, 3.15 here I come.
#26 ·
going to heavier wheels will probably kill your gas milage a little. My heavy breytons cause me to lose about 1mpg in city driving.
The slight increase in rpms shouldn't be bad for motor. it was really that bad... BMW wouldn't put 3.46 diffs on manual tranny 323/325CICs.
