I've been kicking myself about the QuickJack that was on craigslist for $700 that I'd had to pass on when I first found out that I was going to have to buy my house back in August and have been looking for another and only new ones are available for around $1400. It's gotten my looking at things like this one that would get the car twice as high and less obstruction on the sides.Hey, what lift is that? When I built my house I had planned on installing a lift, only to find my garage ceiling was about 4" too short (yeah, poor planning on my part). That looks like it would work perfectly for my needs. I just turned 60 (what an old fart) and am finding I just HATE crawling under cars these days. I think a lift like yours would keep me in the game. Even if I cannot walk under it, if I could get a cheap vinyl office car to slide under with, I think I would enjoy a lot of this as much or more than I used to, instead of just hating under car work these days.
Update: ZHP has been running well. Still giving it it's extended shake down. Several trim pieces are arriving for replacement and I am researching which method I will go to address the burnt ZKW Xenon bowls...
In the meantime, I noticed one of my daughter's tires was failing. Not exactly something I had seen before, but these were some funny brand tires that were on her first E46 that I swapped over to replace the rotten Michelins that were on it when I bought it. I knew these tires weren't great, but the tread was still good, so my frugal side wanted to use them up. In hindsight I should have replaced them last year.
Ive just done my 2003 330D Sport Touring !!!! OOOOOH its good, you do need to get a manual diff though, trust me..
Also, it needed rear shock mounts. It was really complaining back there, so I swapped those with Meyle HD and reinforcing brackets and noticed the rear springs we broken - as usual. They were broken more significantly than ones I have seen previously - I think they broke 2 or 3 times losing more of the spring each time. So I grabbed the nearly new springs out of the donor and with the new Conti PureContact LS tires, this thing drives sweet now. All that is left is to sort the PS leak and finally nail down the stubborn O2 sensor codes to clear the check engine light. I am going to start with the reservoir and the two hoses that attach to it and see if that is everything, or just the major part.
This car, an '03 325i sedan should be getting an auto to 5 speed manual swap this winter. That should be fun and something I haven't done yet.
I think that I retreived all of your post from within the quote that it got mashed up in.Ive just done my 2003 330D Sport Touring !!!! OOOOOH its good, you do need to get a manual diff though, trust me..
The coating is not hardened and shouldn’t be wiped as it will smear offMy understanding is that trying to clean the reflector bowls usually results in messing them up. I cleaned my projector lenses but was very careful not to touch the inside of the bowls.
