:facepalm:
I am this close to removing the engine from my 325ci but my exhaust manifold bolt is stuck, infact it looks like it is welded there. treid drilling, tried using dremel, tried the craftsman nut splitter! The nut is rounded off, the nut splitter splitted the nut at the top but still the nut is just stuck there holding the whole exhaust!:banghead: The other three nuts came off as they were holding the clamp that seperated from the exhaust itself! the outer most nut is :censor: me!
Can't even take it to a exhaust shop as my car doesn't run! should I call mobile welders to use some heat? I doubt they would want to work in some tight spaces like this lying on the ground!
I was thinking if I could just leave the exhaust connected and start pulling the engine out! I am pulling the transmission along with the engine, removed the drive shaft completely!
Have anyone tried pulling the engine out without seperating the exhaust fromt the manifold? I have removed the whole of the front so I will be pretty much pulling the enigne horizontally after the oil pan clears the steering rack.
NEED SOME HELP! My whole progress stopped nice last 2 days coz of this stupid bolt!
