For those that don't want to open docs, here is my part list:
Item, Part #, #, Cost, Vendor
Shifter
ZHP 6 speed knob, 25117896886, 1, $75, BMWminipartsstore
Shifting arm, reinforced, 25117523846, 1, $0, Included with transmission
Bush bearing oval, 25117519670, 2, $12.7, FCP Euro
Shifter bearing pin - left, 25117529078, 1, $5.48, FCP Euro
Shifter bearing pin - right, 25117529079, 1, $5.48, FCP Euro
Shift rod circlip, 25117571899, 1, $1.25, FCP Euro
Shifter bearing (ball socket), 25111220600, 1, $4.62, FCP Euro
Shifter (selector) shaft seal (15X21X5), 23117531360, 1, $21.25, FCP Euro
Selector Rod Joint, 25117580281, 1, $22.49, FCP Euro
Shifter bushing - shifter idler arm rear mount, 25111222015, 1, $34, Marin BMW
Driveshaft
ZHP driveshaft, 26117523913, 1, $0, Included with transmission
M3 flex disc, 26112226527, 1, $60, FCP Euro
Flex disc nuts, 07129900047, 6, $7.98, FCP Euro
Center support bearing, 26127501257, 1, $25.08, FCP Euro
Butyl tape, 26127511140, 1, $4.74, FCP Euro
Intermediate ring, 26117514120, 1, $4.72, FCP Euro
Driveshaft End Bushing - Corteco, 26117526611, 1, $5.97, FCP Euro
Transmission
6-Speed transmission GS6-37BZ, 23007532498, 1, $500, Craig’s List
Transmission plug, 23117531356, 2, $21.04, FCP Euro
Torx Asa-Bolt - M8X50 - transmission, 23001222887, 3, $6, BMW SF
Starter mount torx bolt M10X65 - transmission housing, 07129904681, 2, $9, BMW SF
Torx bolt M12x90 transmission housing, 23001222894, 2, $14, BMW SF
Torx bolt M12x50 transmission housing, 23001222891, 2, $10, BMW SF
Clutch
Clutch kit - Luk - pressure plate, clutch disc, release bearing, pilot bearing, clutch fork, and alignment tool, 21207531556, 1, $226.39, FCP Euro
Twin Mass Flywheel - Luk, 21207533868, 1, $383.37, FCP Euro
Flywheel bolt (M12X1,5X29,15), 11227519572, 8, $46.56, FCP Euro
Clutch fork pin, 21511223328, 1, $9.95, FCP Euro
Clutch release spring clip, 21517570284, 1, $4.29, FCP Euro
Clutch fillister screw (M8X16-ZNS3 MK), 07119906045, 6, $4.62, FCP Euro
Rubber clutch line grommet, 21521165819, 1, $3.43, FCP Euro
Mounts
Engine mount nut, 22116779973, 2, $7.08, FCP Euro
M3 engine mounts, 11812283798, 2, $78.86, FCP Euro
Hex nut (transmission mount), 22116779970, 2, $0.74, FCP Euro
Engine
ZHP Engine, , 1, $500, Craig’s List
AC belt - Contitech, 11287512762, 1, $5.22, FCP Euro
Idler pulley, 11287841228, 1, $14.99, FCP Euro
Water pump pulley + belt, 11511436590, 1, $32.85, FCP Euro
Drive Belt Tensioner Pulley - INA OEM, 11281748131, 1, $10.2, FCP Euro
Intake
CVV Valve , 11617501566, 1, $23.99, FCP Euro
Oil separator hose - valve cover to CVV, 11611432559, 1, $13.39, FCP Euro
Oil separator hose - connecting hose to CVV, 11617504535, 1, $13.78, FCP Euro
Breather hose - vent valve to dipstick tube, 11157532649, 1, $8.42, FCP Euro
Breather hose - Return - Oil separator hose to valve cover, 11617504536, 1, $12.49, FCP Euro
Air filter housing clip, 13719071752, 1, $5.93, FCP Euro
Vacuum hose - CRP, 11731259994, 1, $3.83, FCP Euro
Mercedes vacuum power adapter - O2Pilot mod, 1170780681, 1, $4.14, FCP Euro
Check valve for vacuum system, 11611312737, 1, $13.81, FCP Euro
Seals
DISA gasket, GA-BM-DISA-ORING-M54-S, 1, $5.65, German Auto Solutions
Intake manifold gasket, 11611436631, 1, $53.26, FCP Euro
Engine air distribution o-ring, 11617502761, 6, $5.94, FCP Euro
Dipstick upper o-ring, 11431717666, 1, $0.21, FCP Euro
Dipstick lower o-ring, 11431740045, 1, $5.85, Amazon
Oil filter housing gasket, 11421719855, 1, $9.09, FCP Euro
Valve cover gasket kit, 11129070990, 1, $18.49, FCP Euro
Valve cover grommets, 11121437395, 15, $10.35, FCP Euro
Oil pan gasket, 11131437237, 1, $19.99, FCP Euro
Oil pan bolt, 11131740000, 21, $25.41, FCP Euro
Oil pan long bolt 1, 11131435806, 1, $3.02, FCP Euro
Oil pan long bolt 2, 11131435807, 1, $1.48, FCP Euro
Throttle body gasket, 13547504729, 1, $4.99, FCP Euro
Crankshaft position sensor o-ring, 12141748398, 1, $0.87, FCP Euro
Rear main seal kit, 11141438274, 1, $117, FCP Euro
Coolant plug, 07119904539, 1, $1.98, FCP Euro
Coolant washer, 07119963200, 1, $0.18, FCP Euro
Power steering pump hose gasket, 64508390601, 1, $0.25, FCP Euro
VANOS
VANOS seals, BS001, 1, $60, beisansystems.com
VANOS anti-rattle kit, BS002, 1, $60, beisansystems.com
OFHG VANOS line banjo washers, 32411093596, 2, $2.46, FCP Euro
VANOS gasket, 11361433817, 1, $6.75, FCP Euro
VANOS piston bolt, 11361748745, 2, $10.56, FCP Euro
VANOS oil line, 11361705532, 1, $27.99, FCP Euro
Exhaust
Exhaust flange gasket, 18107502346, 2, $32.5, FCP Euro
Exhaust flange copper nuts - Volvo, 18301737774, 4, $1.92, FCP Euro
Exhaust hanger lower bracket, 18101433250, 1, $7.09, FCP Euro
Exhaust transmission hanger, 18301436331, 1, $6.79, FCP Euro
Exhaust hanger bolt, 07119902957, 1, $3.72, FCP Euro
Secondary air injection gasket, 11727505259, 1, $2.54, FCP Euro
Body
Reinforcement plate bolts, 17511, 16, $9, Bolt Depot
Reinforcement plate bolts , 17743, 16, $1, Bolt Depot
Cooling
Water pump - BMW, 11517509985, 1, $0
Water pump o-ring - Reinz, 11511711484, 1, $1.59, ECS Tuning
Thermostat - Borg-Warner, 11537509227, 1, $48.99, FCP Euro
Heater hose - engine inlet and water valve - Rein, 64218376999, 1, $13.87, FCP Euro
Coolant return hose - Rein, 11531436410, 1, $18.95, FCP Euro
Heater hose - radiator and expansion tank - Rein, 64218376153, 1, $27.73, FCP Euro
Heater hose - water valve and radiator - Rein, 64218363198, 1, $13.53, FCP Euro
Radiator - Nissens, 17119071518, 1, $74.99, FCP Euro
Heater hard line - inlet pipe, 11531705210, 1, $30.81, FCP Euro
Cooling hard line, 11537502525, 1, $40.85, FCP Euro
Electrical and Sensors
ZHP Cluster manual convertible, 62108036649, 62107905493, 62107919673, 1, $119, eBay
Oil temperature sensor, 13621433076, 1, $11.35, FCP Euro
Fluid level sensor, 17137524812, 1, $27.18, FCP Euro
Maintenance
Transmission fluid - liter, Red Line D4ATF, 2, $15, NAPA
BMW Coolant 4 liter container, BMW, 2, $40, BMW
Mann-Filter*X Metal-Free Oil*Filter, HU 925/4, 1, $7.49, Napa Auto Parts
Rotella T6 4 liter container, Rotella T6, 2, $40, O’Reillys
