1 - 1 of 1 Posts
Hello community. Originally posted on zhpmafia. I've had my 2004 ZHP sedan for over a year, typical ZKW burnt bowls. After lots of research, last December, I finally decided to tackle this project. I went with Morimoto Mini D2S 4.0 projectors based on a few pictures I saw online. What drew me to this projector was the definition and width of the cutoff.
http://www.youtube.com/watch?v=mSJQ9XpqaaY
The project is definitely not plug and play but if you have the tools it's another option to consider. I finally got through sorting over 150 pictures and instead of doing the step by step here, I annotated the images. Sorry for the few grammar errors, busy schedule so I was working at night.
I'm making this tutorial newbie friendly so if you've never tinkered with your headlights you'll find useful pictures. However, by the time I was ready to install these things I kind of stopped taking pictures, too excited to see the lights in action. I did take pictures of the final result and a little driving clip included in the end.
Components
Morimoto Mini D2S 4.0 from Lightwerkz
http://www.lightwerkz.net/index.php...i-xenon-morimoto-mini-d2s-4-0-projectors.html
E46-R shrouds also from Lightwerkz
http://www.lightwerkz.net/index.php/components/projector-shrouds/e46-r-projector-shrouds.html
Morimoto XB D2S 5500K bulbs
http://www.lightwerkz.net/index.php/components/hid-bulbs/morimoto-xb35-d2s-bulbs.html
Tools
- flat blade screwdriver
- pocket size flat blade screwdriver
- phillips screwdriver
- interchangeable bit screwdriver
- 6" magnetic hex bit extension
- T25 driver
- T15 driver
- 8mm socket
- ratchet, 3/8" or 1/4" doesn't matter
- ratchet extension (optional)
- magnetic parts holder (optional)
- locking clamp pliers or needle nose pliers
- Dremel 3000 kit
- drill
- 1/16" drill bit
- 3/32" drill bit
- soldering iron w/ solder
- 18-22 gauge heat shrink wrap
- pick tools, various angles
- Sharpie
- pen
- painters/masking tape
- JB Weld
- Blue Magic polishing cream
- #6 x 1/2" phillips sheet metal screws
- #6 - 32 x 3/4" machine screws with matching nuts
- #6 flat washers
- 1 1/2 flat corner braces
Part 1
Headlight removal
step001 by fatherlemmisty, on Flickr
step002 by fatherlemmisty, on Flickr
step003 by fatherlemmisty, on Flickr
step004 by fatherlemmisty, on Flickr
step005 by fatherlemmisty, on Flickr
step006 by fatherlemmisty, on Flickr
step007 by fatherlemmisty, on Flickr
step009 by fatherlemmisty, on Flickr
Now use your ratchet and 8mm socket to loosen the front screws
step010 by fatherlemmisty, on Flickr
For the rear screws you'll use your screwdriver with magnetic extension and T25 driver. (Not pictured.)
step011 by fatherlemmisty, on Flickr
step012 by fatherlemmisty, on Flickr
step013 by fatherlemmisty, on Flickr
Headlight disassembly
Take your headlights inside the house, I recommend working on a table. Here's the Morimoto unit.
step015 by fatherlemmisty, on Flickr
step017 by fatherlemmisty, on Flickr
This trim comes off pretty easy.
step018 by fatherlemmisty, on Flickr
step019 by fatherlemmisty, on Flickr
step020 by fatherlemmisty, on Flickr
step021 by fatherlemmisty, on Flickr
step022 by fatherlemmisty, on Flickr
step023 by fatherlemmisty, on Flickr
step025 by fatherlemmisty, on Flickr
step026 by fatherlemmisty, on Flickr
step027 by fatherlemmisty, on Flickr
step028 by fatherlemmisty, on Flickr
step029 by fatherlemmisty, on Flickr
step030 by fatherlemmisty, on Flickr
step031 by fatherlemmisty, on Flickr
I believe this was a Torx 15 driver, sorry for the grammar.
step032 by fatherlemmisty, on Flickr
While this one Torx 25, but don't quote me on this haha
step033 by fatherlemmisty, on Flickr
step034 by fatherlemmisty, on Flickr
step035 by fatherlemmisty, on Flickr
step036 by fatherlemmisty, on Flickr
step038 by fatherlemmisty, on Flickr
step039 by fatherlemmisty, on Flickr
I meant the burnt projector bowl
step040 by fatherlemmisty, on Flickr
step041 by fatherlemmisty, on Flickr
step042 by fatherlemmisty, on Flickr
The heat also burned the driver's side shroud. Bummer. I would've reused the OEM shrouds.
step045 by fatherlemmisty, on Flickr
For comparison, the ZKW lens is frosty while the Morimoto is all clear.
step047 by fatherlemmisty, on Flickr_a_
1 - 1 of 1 Posts
