1 - 5 of 5 Posts
I have just had my compressor to condenser hose extened to work on my LS swap. One of the guys at work TIG welded a pipe sleeve into the metal part of the hose to extend it 3" for me.
In the process he melted off the little yellow plastic end that is just before the O-ring.
Do you think the yellow plastic tip is necessary? The best we can figure is that is there to retain the O-ring when the hose is removed. The o-ring creates the seal so do you think I need the yellow plastic tip, and if so why?
E39 E90 E46 F10
That's a locator so the o-ring is compressed evenly as you crank down the securing bolt (which inevitably applies a force to the o-ring against the wall towards the clockwise rotation.
I think I still have one from my last AC hose repair. I'll put it in the mail if it's that important to you but I imagine you can fashion one pretty easily.
Discussion Starter #4
If you happen to have the one that goes on the compressor end of the compressor to condenser hose I would be happy to pay you for it. The hoses all seem to have different sized ends on them.
I don't know how I would make one. Are they able to be removed and re-used on another hose?
Discussion Starter #5
Just a quick follow up to let you guys know I picked up a used hose at you-pull-and-pay and pay. I was able to gently coax the yellow plastic tip off with a flat screwdriver and re-use it on my modified hose.
No further reason for concern.
1 - 5 of 5 Posts
