1 - 20 of 38 Posts
Super Moderator
2003 330cic, 2003 325iT
I know the world likely doesn't need another torque guide but I have been keeping a doc on my iPhone that I use when I am restoring E46s. I have leaned heavily on the two big efforts in the past:
The Ultimate e46 M54 Torque Specs Thread
Ultimate BMW E46 M3 Torque Spec Guide
This is also useful:
Know your nuts?
I added a bunch of more esoteric specs and organized it in a way I could understand more. I hope it is useful for you.
Body
Wheels
Lug nut 118Nm (87 ft-lbs)
Bumper
Bumper torx 41Nm (30 ft-lbs)
Bumper shock 22Nm (16 ft-lbs)
Front bumper bracket M10 55Nm (41 ft-lbs)
Doors
Hinge 20Nm (15 ft-lbs)
Door check 24Nm (16 ft-lbs)
Window regulator rail to door 9Nm (80 in-lbs)
Window motor 5Nm (44 in-lbs)
Other
Sunroof headliner to rails - 4.5Nm (40 in-lbs)
Wiper arms - 25Nm (18.5 ft-lbs)
Interior
Steering wheel bolt 62Nm (46 ft-lbs)
Seats - 45Nm + 90°
Airbags
Side-impact airbag to door - 8.5Nm (75 in-lbs)
Passenger airbag to dashboard - 22Nm (16 ft-lbs)
Engine
Chain tensioner - 70Nm (51 ft-lbs)
Crankshaft "Jesus" bolt - 410 Nm (300 ft-lbs)
Pulleys and Belts
Drive belt tensioner
  • Tensioner body - 24 Nm (18 ft-lbs)
  • Pulley (11281748131) - 45 Nm (33 ft-lbs)
Drive Line Idler Pulley (11287512758) - 45 Nm (35 ft-lbs)
Alternator hydraulic tensioner
  • Pulley (11287841228) 45 Nm ( 35 ft-lbs)
Cooling
Coolant plug - 25Nm (18 ft-lbs)
Water Pump
Body - 10 Nm (7.4 ft-lbs, 89 in-lbs)
Pulley - 10 Nm (7 ft-lbs)
Thermostat
3 Identical Bolts - 9.9 Nm (7.3 ft-lbs)
Housing bolt right M8X30 - 24 Nm (17.7 ft-lbs)
Alternator
Alternator to crankcase M8 - 21Nm
Idler pulley to alternator - 45 Nm
Positive terminal - M8 - 13 Nm
Starter
Starter flange to transmission - 43Nm (32 ft-lbs)
Solenoid lead to starter - M5 - 5Nm (44 in-lbs)
Electrical leads - M5 (5 Nm), M6 (7 Nm), M8 (13 Nm)
AC Compressor
Compressor mounting bolts - 20 Nm (15 ft-lbs, 177 in-lbs)
A/C line to A/C compressor - 20 Nm (15 ft-lbs, 177 in-lbs)
Refrigerant line to body - 5.5 Nm (48 in-lbs)
Double pipe to expansion valve - 8 Nm (71 in-lbs)
Valve Cover
Spark plugs - 30 Nm (22 ft-lbs)
Valve Cover (Bolts & Stand-Offs) 10 Nm (84 in-lbs)
VANOS
VANOS housing piston covers 10Nm (84 in-lbs)
VANOS Oil Hose from Oil Filter Housing (Hose with Hollow Bolt) - 32Nm (23.5 ft-lbs)
Reverse Thread VANOS Bolts Connecting VANOS to Cam Shafts - 8 Nm (71 in-lbs)
VANOS Piston Plug Caps - 50 Nm (37 ft-lbs)
VANOS solenoid to VANOS control unit - 30Nm (22 ft-lbs)
VANOS mounting nuts (6) - 8 Nm (6 ft-lb)
Engine hanger nut and bolts- 10 Nm (7 Ft-lb)
Camshaft position sensor - 5 Nm (44 in-lbs)
Timing Chain Cover
5Nm, then drive pins, then 10Nm (84 in-lbs)
Oil sump/oil pan
Oil drain plug - 25Nm (18.5 ft-lbs)
Oil pan
  • 8,8 - 10Nm (88 in-lbs)
  • 10,9 - 12Nm (106 in-lbs)
  • Tranmission housing transverse bolts
Oil pump sprocket nut (reverse thread) - 25Nm (18.5 ft-lbs)
Oil level sensor - 10 Nm (88.5 in-lbs)
Oil filter housing
6 OFHG bolts - 22Nm (16 ft-lbs)
VANOS oil line - 32Nm (24 ft-lbs)
Dipstick support - 22Nm (16.2 ft-lbs)
Sensors
Coolant temperature sensor 13 Nm (115 in-lbs)
Camshaft position sensors (2) - 3.5 Nm (36 in-lbs)
Oil pressure switch - 27Nm (20 ft-lbs)
Oil temperature sensor - 27Nm (20 ft-lbs)
Pre-cat O2 sensor - 50 Nm (37 ft-lbs)
Crankshaft sensor - 10 Nm (7 ft-lbs)
Exhaust
SAP vacuum pump on cylinder head - 10Nm (88 in-lbs)
Exhaust manifold to cylinder head - 20Nm (15 ft-lbs)
Exhaust flange to exhaust manifold (M10) - 30Nm (22 ft-lb)
Intake
DISA, IAC and Throttle body - 10Nm (88 in-lbs)
Harness electrical box - 10Nm (88 in-lbs)
Intake Manifold
  • M7 Nuts - 15Nm (132 in-lbs)
  • M8 Nuts - 22Nm (16 Ft-lbs)
Fuel rail - 10Nm (88 in-lbs)
Brakes
Brake hydraulics
Master cylinder to booster - 26Nm (19 ft-lbs)
Booster to pedal assembly - 25Nm (18.4 ft-lbs)
Calipers
Brake rotor retaining screw - 16Nm (12 ft-lbs)
Front Bracket - 110Nm (81 ft-lbs)
Rear Bracket - 65Nm (48 ft-lbs)
Guide pins - 30Nm (22 ft-lbs)
10-15lbs for pressure bleeder
E-Brake and Shield
Small rear brake shield screws - 10Nm (88 in-lbs)
Large rear brake shield screws - 18Nm (160 in-lbs)
E-brake cable clamp (on trailing arm) - 10Nm (88 in-lbs)
Steering
Power steering fluid reservoir
  • Clamp screw - 5.5nm (49 in-lbs)
  • Mounting bolt - 22Nm (16 ft-lbs)
Steering pump
  • Steering pump mounting bolts - 22Nm (16 ft-lb)
  • Steering pump pulley bolts - 22Nm (16 ft-lb)
Steering rack to front subframe - 43Nm (32 ft-lbs)
Steering column flex disc/giubo clamping screw - 22Nm (16 ft-lbs)
Tie rod end to tie rod - 45Nm (33 ft-lbs)
Tie rod joint to rack 100 +10Nm (74 +7 ft-lbs)
Tie rod end to knuckle - 65Nm (48 ft-lbs)
Pressure hose bracket to rack 5mm bolt - 22Nm (16 ft-lbs)
Pressure hose to rack - 19mm/M14 - 33Nm (25 ft-lbs)
Pressure hose to pump - 40Nm (30 ft-lbs) - 17mm crows foot
Return hose to rack - M16 Banjo 40Nm (30 ft-lbs)
Undercarriage
Most nuts on undercarriage are single-use self-locking nuts (hole looks a little oval)
Front Subframe
Engine mount bracket to engine - 22Nm (16.2 ft-lbs)
Engine mount
  • M8 22Nm (16 ft-lbs)
  • M10 47Nm
Front sub-frame to frame rail bolts (10.9 grade) - 110Nm (81 ft-lbs)
Front end reinforcement to front subframe or body frame rails - 59Nm (43.5 ft-lbs) (90+30°)
Motor mount - 45Nm (33 ft-lbs)
Exhaust
Heatshield 10Nm (88 in-lbs)
Muffler hanger nuts (13mm) - 22Nm (16 ft-lbs)
Muffler chassis plate - 22Nm (16 ft-lbs)
Exhaust pipe to manifold - 30Nm (22 ft-lbs)
Convertible V-Strut
V-strut large bolts (if 10mm) 59Nm+90°
V-strut small bolts (M8X16-Z1) 22Nm (16 ft-lbs)
Suspension
Most nuts on suspension are single-use self-locking nuts (hole looks a little oval)
Front Suspension
Control arm bracket (bushing bracket) to frame rails - 60 Nm (44 ft-lbs)
FCA Inner ball joint to subframe - 89.5 Nm (66 ft-lbs)
FCA Outer ball joint to steering arm - 65 Nm (48 ft-lbs)
Stabilizer bar bushing to frame rail nut - 22Nm (16 ft-lbs)
Steering arm pinch bolt at strut housing - 81Nm (60 ft-lbs)
Front end link - 65 Nm (48 ft-lbs)
Front strut assembly to strut tower (self-locking nuts) - 24Nm (18 ft-lbs)
Front upper strut mount to strut shaft M14 - 64Nm (47 ft-lbs)
ABS/wheel speed sensor - 8Nm (71 in-lbs)
Rear Suspension
Rear shock to trailing arm - 100Nm (74 ft-lbs)
Rear shock to top mount - 13.5Nm (120 in-lbs)
Rear shock top mount to body - 28Nm (21 ft-lbs)
Rear end link mounts - 17mm bolt head - 34Nm (25 ft-lbs)
Rear end link transverse bolt - 24Nm (17.7 ft-lbs)
Rear sway bar mounts - 13mm nut and bolt - 22Nm (16 ft-lbs)
Rear Subframe/Carrier
Carrier support - 13mm bolts - 21Nm (15 ft-lbs, 186 in-lbs)
Carrier heat shield 10Nm (88 in-lbs)
Front/Rear fasteners to frame - 77Nm (57 ft-lbs)
Control Arms
Upper control arm inner - 77Nm (57 ft-lbs)
Lower control arm inner - 110Nm (81 ft-lbs)
Upper control arm outer - 110Nm (81 ft-lbs)
Lower control arm outer - 110Nm (81 ft-lbs)
Trailing Arm
RTAB bushing transverse bolt - 110Nm (81 ft-lbs)
RTAB mount bolts to frame - 77Nm (57 ft-lbs)
E-brake clamp - 10Nm (7.4 ft-lbs)
Transmission and Drivetrain
Giubo/flex disc nuts are single-use. Recommend replacement of torx bolts.
Transmission to Engine
M8 Torx - 22 Nm (16 ft-lbs)
M10 Torx - 43 Nm (32 ft-lbs)
M12 Torx - 72 Nm (53 ft-lbs)
Manual
Clutch master to pedals - 20 Nm (15 ft-lbs, 177 in-lbs)
Clutch slave to transmission - 20 Nm (15 ft-lbs, 177 in-lbs)
Fluid line to master cylinder or slave cylinder 20 + 5 Nm (15 + 4 ft-lbs)
Transmission fill plug 50Nm (37 ft-lbs)
If allen head - 35Nm (26 ft-lbs)
Transmission mounts -21 Nm (15 ft-lbs, 186 in-lbs)
Transmission cross member to Chassis - 21Nm (186 in-lbs)
ZF Auto transmission
Drain plug - 35Nm (26 ft-lbs)
Fill plug - 30Nm (23 ft-lbs)
Pan/sump to transmission - 6Nm (48 in-lbs)
Filter - 9 Nm (78 in-lbs)
Differential
When reinstalling, insert all 3 bolts finger tight. Tighten the 2 front bolts first, then tighten down the rear bolt
Differential fill plug - 70Nm (52 ft-lbs)
Differential front mount bolts (18mm) - 95Nm (70 ft-lbs)
Differential rear mount bolts (21mm nut and bolt) - 174Nm (128 ft-lbs)
Differential cover (per TIS)
  • M10 8.8 - 45Nm (33 ft-lbs)
  • M10 10.9 - 55Nm (41 ft-lbs)
Driveshaft and Axles
Front axle nut - 290Nm (214 ft-lbs)
Rear axle nut - 300Nm (221 ft-lbs)
Flex disc/giubo - 100Nm (74 ft-lbs)
Center Support Bearing to body - 21Nm (15 ft-lbs)
Driveshaft to Rear Differential Flange (E12 torx) - 85 Nm (63 ft-lbs)
Rear Axle Bolts to Rear Diff (E12 torx) - 83 Nm (61 ft-lbs)
Misc
Convertible roof hinge bolts - M8-ZNS-3 24Nm 17.7 ft-lbs
Super Moderator
Discussion Starter · #3 ·
Very useful thank you Archbid. I have a question on the oil pan bolts. I see there are 2 listings as 8.8 and 10.9. All of my bolts have 8.8 on the head so what are the 10.9 ones? :dunno:
Every source I found listed both, so I put it in when I was preparing for the job. I only have 8.8 as well. Every time I do a job I make a list of all the fasteners and their torque settings so I am not doing web searches or looking in the Bentley in the middle of the job.
//Binary is in my DNA
2002 BMW 325i
Thank you so much! I will be using your guide as I have so much apart right now on my X5 just waiting on the oil to stop dripping in the front left corner seam so my sealant will dry properly without oil contamination when I put the oil pan back on. 3 days now and still coming down. :banghead:
Super Moderator
Discussion Starter · #6 ·
Take the tip of a rag and wipe the inside edge of the block up about 1cm. The stuff dripping from the driveshaft and pump won't be an issue, just the seeping down the walls. Wipe the inside edge and buy yourself 10 minutes to get the pan in place.
2002 BMW 325i
Yeah I am probably just being over cautious and paranoid. The instructions on the Dreibond 1209 sealant is 3 fold torqueing. 3 ft/lbs initially. Half torque at 1 hour and final torque 6-24 hours later. I just don't want any oil in the sealant, God knows I don't want to do this OPG twice.
Super Moderator
Discussion Starter · #8 ·
I have done three oil pans since January. It is one of my least favorite tasks.
Though oddly the only one that always makes me angry is the damn hinge cover slides and springs on the convertible. ;)
BTW, I highly recommend a digital torque wrench if you are going to do a lot of DIY, if only because you can do Nm as your default. Tekton wrenches are fine, but they are made for ft-lbs/in-lbs and that is just irritating.
2002 BMW 325i
I bought the Craftsman 3/8 Digi-Click for the job. It will display Nm, in/lbs or ft/lbs.
2002 BMW 325i
How much that bad girl run you?
Sent from my ONEPLUS A6000 using Tapatalk
I think $150 is retail as Archbid suggested but I got mine new off a fleaBay seller for $89 delivered. :thumbup:
OEM ///PLUS
2003 M3 6MT Slicktop
It is about $150, and it is the one I use. Only gripe is that it only works clockwise. Otherwise perfectly useful.
..and the screen readout is a tad small. and that’s on my 1/2” big boy.
ratchet head could be larger too.
Super Moderator
Discussion Starter · #16 ·
2005 e46 330xi 6spd
Arch, I think you have a typo in the oil pans specs. For the 8.8 bolts you have a higher torque than the 10.9 bolts, and the imperial units don't work out.
My Bentley has 10nm/8.8 and 12nm/10.9 for the m6 bolts and 22nm/8.8 for the m8 (xi oil pan).
2002 BMW 325i
Still a discussion on the 2 different torque specs for the 8.8 and 10.9. I wonder if the 10.9 bolts are the 3 torx bolts from the trans bell housing to oil pan? If not, does anyone what would those torque specs be for those 3 lateral fasteners. :dunno:
I hear you. I changed mine about 3 years ago or so on the 330 and I am getting ready to do it on the 323, it's a lot of work and time consuming but not difficult.
1 - 20 of 38 Posts
