1 - 20 of 23 Posts
Nice ride:thumbup:
Rolling on Dubs. Got Boost?
Damn the looks good!!!
I need to finally get my ass moving and get the M3 mirrors installed.
ehhhhh must not...not get new rims...nooooo :flipoff:
:D
(i'm trying to keep myself from buying new ones....)
What size are they btw?
Discussion Starter #10
Yeah Charlie the bases came out sweet. I needed to do a little bit more grinding on order for the bolts to sit flush on the door when mounting but they came out perfect.
Why rims are 19"s. I actually painted them with the titanium silver paint from the curb rash DIY cause I had major curb rash. I think they came out great and now if I ever scratch them I can repaint them very easily.
Gotta love these upgrades on a wagon
D1Trupinoy:
You mentioned a "little more grinding" needed. Can you describe the nature of the mods required to fit the M3 mirror bases? I realize the mounting holes and/or locations are different. Do you alter the mirror bases to match the car door or vice-versa? Can you provide any pictures of the required changes to door/mirror base?
I've looked through most of the threads on M3 mirror upgrades and have not seen anything that provides specific guidance as to how to properly locate & mount the new bases.
Any help would be greatly appreciated.
Discussion Starter #13
Stealth,
I got the bases moded from Charlie (Yellowman). Once you have the bases you will see that the mounting holes for the M-3 base line up with uneven area of the door. So what I did is drill the holes until they lined up, then cut with a dremel the uneven areas to make them flat for the bolt to sit correctly. The area you cut is a 2 layer sheet metal so I actual just cut the interior layer so I can mount the bolt onto the second (exterior layer). I also grinded a small notch on the exterior door where the plate would sit on (there is a flap of metel right under the mirror base (this flap is parralel to the ground)). I cut a small notch so the base sits on a groove and more level with the mounting area.
You will understand what I mean once you try to install. Sorry I took no pics cause I was so caught up in finishingmy car mods.
d1trupinoy said:
Stealth,
so whats the point of sending the bases to bodywerks if all this additional work is necessary?
Why not just follow RE DIY?
Just my $0.02
www.piratecove.org
'cause bw has done lotsa them and will modify them right :)
i love mine
Discussion Starter #16
I still had to send the basses to get moded for a sedan. I still had to drill new holes in my door in order for me to mount the modded base plates. I did additional work on the door in order for the bolts to sit flat when screwing in the mirror bases is what I was explaining.
1 - 20 of 23 Posts
