81 - 100 of 380 Posts
Unfortunately, the inner boots have an asymmetric attachment, and don't easily lend themselves to aftermarket replacements.
Yea I've been reviewing pics plus I need to get my hands on the part. Hoping I can do it in the new few weeks. Snowboarding keeps getting in the way.
I just installed a new suspension a few weeks ago on a car with the drop hats. While installing I found his inner boot had a tear in it also. His car was full stock and the inner only lasted a few months. Granted it was a cheaper one from O'REilly's, I'm going to think use his car as an experiment to see if I can work out a solution for the inner boot.
A solution for the inner boot would be fantastic. The stock boot fits over an adapter which could be transferred to a new boot. The difficulty would be keeping the adapter attached to the boot. The adapter has a ridge that runs around the perimeter that locks into a complementary groove in the boot.
Discussion Starter #87
called it ahah, thanks for the link ;)
Taking a mini vacation......
If you do more searching those turned out to be a complete failure, I don't recommend the KYB's.
Rob43
Banned
That thread said that they fail faster than expected. The other issue is that the car they are meant for weighs more than 1000 pounds less than ours so the valving and what not isn't ideal.
yeah thats why i brought up the KYB's for Fbodies, that everyone has been using on e30's and e36's for years... the AGX adjustables, and are shorter than the stock with decent valving. Ive ran em many times on an e46, and assumed when i saw AGX's that what you guys were running.
Banned
http://www.jegs.com/i/KYB/575/743019/10002/-1?CAWELAID=1710915981&CAGPSPN=pla&catargetid=230006180003463234&cadevice=c&gclid=COX8mP2-jssCFbYW0wodO_8E6w
These will outperform most other adjustable's, wont blow, dont have too much free travel, and acutally work if you guys are into that kind of thing ;p
Except the bottom mount on those is 5/8" (15.875mm) and the bottom mount on our cars is 12mm. Everything else seems fine, and if you can get a bushing made to fill that tiny gap you would be golden. 3mm is a very small amount but I would consider looking elsewhere.
lol dont try to reinvent the wheel, it comes with bushings, and you can just reuse your old bottom rubbers. This has been tried and tested for i dunno the last 15 years ;)
Discussion Starter #96
Everyone needs to understand that I tested those kyb's too, they simply aren't a good shock to use for the E46 chassis.
Besides not fitting properly because of the bottom mount, which of course need to be shimmed or replaced to make it work,......they're REALLY a bad choice based on the fact that they are to Short in compressed length & extended length.
Rob43
Banned
But why run them when we have the option of Rob43's shocks (if anyone can get a hold of him to find out what they are....)
*too short for cars on lowering springs.. sorry guys i was reffering to really low cars (ie: coils, bags, etc..)
I have a RWD e46 now, but when i had my XI shortened and re valved e36 M3 rears, and Eibach ERS linears #650 was my favorite setup ;)
I was thinking you guys all wanted to make coils ETC, that is why i recommend such short bodied shocks, my bad :(
Really miss my silver XI ;( You guys should look into making front coils, it was very simple, I was on the hunt for 52mm bodied fronts that are shorter, but the pinch bot design on the XI hub was making that difficult...then car turned into a pop can and i lost interest. I found a couple coilover bodies (like empty housings) that would work well if anyone ever is curious about making good coils yourself:hi:
Discussion Starter #100
@rob are there shorter version of your shock available? if so id be interested :)
Yes.
PM's fill up daily, send me an Email to discuss.
Rob43
