1 - 3 of 3 Posts
2001 330ci-up till last week, headlights always did the selfadjust dip, now they just come on, no dip down then up?
what could be the problem? is there a problem?
thanks
doug hunt
There is a fault in the headlight leveling system and leveling has been disabled. Check the right hand lower control arm. There should be a sensor connected to it. Often, the sensor gets disconnected from the control arm or broken off completely which will put the leveling system in default mode.
If it looks OK, you will need to have the LSZ scanned to see what fault is present.
here is a picture of the assembly. M3 shown, non M similar.
Discussion Starter · #3 ·
Thanks, i will check it as soon as it stops raining here, i think we are supposed to get some decent weather sat/sun.
doug
1 - 3 of 3 Posts
