1 - 3 of 3 Posts
My xenon auto-leveler is only giving the up/down positioning movement if I move the key to position 1 (accessories powered only). When I turn the key quick to position 2 (normal start), there is no up/down movement.
I have the LCM switch pointed at auto headlights.
I'm thinking this may be related to a possible fault code when I had my windshield changed since my rain sensor stopped working after the install.
Has anyone run into this problem with the xenon auto-leveler? Because it will auto-level in position 1 this doesn't seem to be a problem with the arm connected to the suspension.
Discussion Starter #2
Solved.
My Rain/Light Sensor (RSL) could not be coded at all. I bought an RSL on eBay and connected the back part to the preglued lens on my the Mexican-made Pilkington windshield.
The normal up/down movement came back.
Still need to initialize the RSL - apparently it's better if the glass installer slides the back part off the old lens and keeps the harness plugged in.
1 - 3 of 3 Posts
