i have an amp that does the following....and i only want to run one 10 in sub (trying to save as much trunk space as possible)
400 Watts X 1 Channel @ 4 Ohms
700 Watts X 1 Channel @ 2 Ohms
1200 Watts X 1 Channel @ 1 Ohm
can someone be kind enough to tell me which sub configurations are applicable to each amp configuration? for example, i know to run my amp at 400 Watts x 1 @ 4 ohms, i will need a dual 2 ohm sub. what kind of sub ohm config will i need for 700 Watts X 1 Channel @ 2 Ohms and 1200 Watts X 1 Channel @ 1 Ohm . i had this amp sittin in my closet, i figure i might as well use it and save some money.....can anyone lay the smack down for me?
