Hey guys, I have an '02 330ci AT
The windshield washer pump decided not to spray any fluid today... Do the pumps fail randomly without warning? It was working perfectly fine the last time I used it, spraying the fluid quite strongly... There is no response now when I pull on the stalk, and I don't hear any buzzing from the pump either... Just the wipers moving.
Just wondering if there are other issues to consider before replacing the pump?
Also, not sure if it matters, but I have also removed the pump for the headlight washers and plugged the hole for that a while back.. this wasn't an issue as I used the regular washer plenty after that
Thanks in advance for any help
