1 - 4 of 4 Posts
I filled up the washer fluid all the way, and it all leaked out overnight. I saw small drops coming out from the bottom. I assume it's the washer pump, but how can i make sure it's not actually the grommet?
I should probably replace both since I can get the both for $18 shipped or the pump for $15 and grommet for $5 if bought separately.
for those that had this issue, did you fix it by changing both parts?
I replaced both a few weeks ago - problem solved. Not worth my time to go in piece by piece, and I hear that it is quite often the pump anyway.
BK
Just replace the entire pump. If it's not the pump (which it probably is) the pump will die another day
1 - 4 of 4 Posts
