I have a windscreen washer pump (original) that is leaking. There is a split in the tube at the bottom of the pump that connects to the black rubber pipe to the washers.
I have tried to repair the pump connector it but so far without luck.
I have also purchased 2 new pumps but both do not pump water even though the motor seems to run on both?!
The old one still works perfectly but as mentioned leaks.
Any ideas why the 2 new (admittedly not OEM) replacemants do not work?
One is a:-
febi bilstein 23113 Washer Pump (Amazon)
and the other one from EBay
Any thoughts/suggestions most welcome.
One is a:-
