Would it rub the strut or fender? In other words would I need a fender roll or a spacers? Any ideas? Thanks...From what i know, the offsets shouldnt be a problem. Buddy of mine fit a 19x8.5 et 40 // 19x9.5 et45 without any mods. But i think 275 would be rubbing..
Hmmm... I want to run 285's or wider in the rear next time I need to change tires. 9.5" wheels should support them but it sounds like I'd need a fender roll, right? Or would I need spacers? Or both?You are within the recommended specs on the offset. We typically would recommend a 235/35/19 front and 255/30/19 rear tire. People have fit wider tires than these, however I can not guarantee you will not run into any rubbing issues.
You would most likely need some fender modification with a 285 tire! That's pretty wide!
I agree. But I was able to fit 255's with a good amount of clearance on stock fenders a long time ago, and now that im shaved, i feel i could fit 285's. Try a roll, and you could clear.You would most likely need some fender modification with a 285 tire! That's pretty wide!
