1 - 14 of 14 Posts
Rim Size: 18x8.5" front, 18x9.5" rear.
Rim Offset: ET13 front, ET19 rear.
Bolt Pattern: 5x120
Tire Size: 235/40ZR18 front, 265/35ZR18 rear.
"DPErt-ASchnizA-*****"
You'll rub EVERYWHERE!!!!!!!!!!!
just what i was about to say, but i actually have that set-up on my coupe, no rubbing at all, stock height that is.
there is no way you can run that. the offset is WAAAYYYY too low. even for an M3. those offsets sound like its for a widebody
:pimpin:
sorry, i meant the 18x8.5 front and 18x9.5 rear part, and tire size, not offset.
Senior Eurowerkz Member
you should go into the
wheel and tire forum and speak to gary or pete from wheelexperts they will tell you how you should go. so you won't rub on your car.
bobm3 :thumbup: :thumbup:
i ran some bbs rx's et10 for about a month 18x8.5 with no problems, but it was a little wide...but you def have to roll the rear if you wanna put 18x9.5 one...still I wouldnt run et13's theyre gonna stick out to much...
1 - 14 of 14 Posts
