1 - 14 of 14 Posts
Hey guys! im going buy some wheels this weekend and i set my sight on these 19" wheels
but i have a 325i riding on stock.
here is the specs of the tires 235/35/19 front 275/30/19 rear
Im guessing i will need to roll the rear fenders but if i do that will they fit and ride good?
I'm a noob with anything to do with wheels and fitmits. :eek:
Thanks for the Help!! :hi:
:D
You need to know the offsets BUT I don't think a 275 will fit on the rear of a sedan. And it sounds like those are m3 wheels (wrong offset) because those are m3 tire sizes.
make sure you can easily find some replacements because you will likely bend/crack one. Search on this site for damaged 19'' wheels
19's will have you looking like a 4x4 on stock suspension. 275 wont fit a sedan but then again you will be riding so high I don't think it would even matter. Just search for some wheel threads (because there are hundreds) and the showroom for a setup you like the look of and go with those specs.
For a ballpark, if you're looking at 18's on a sedan, your looking for 18x8, 18x8.5, 18x9 with an offset somewhere in the ET35-45 range. Depending if you want a staggered look or not, tire sizes from 225-255. Some say 265 can fit under the rear of a sedan but most likely you'll be doing some fender work there depending on offset. Plus 265 wont look good on stock suspension IMO. Start with that and get them on the car, then you'll likely want some 5-10mm spacers depending. I'm just giving you a place to start, obviously you can do away with the spacers if you can find some more aggressive offsets. If you do find M3 wheels you like, you can run four fronts.
:D
I have a 9.5 with 255 tires running on the rear of my sedan. No fender modification and no running.
OP, if they came off of an E90, most likely they're not going to fit well. Typically on an E90 or E92, they run a 19x8.5 ET35/19x9.5 ET33, and with a 275 in the rear, you're going to rub for sure. Confirm the wheel specs first. If they're 9.5 ET45 rears with the 275s, you can swap the tires for a narrower size and it will work just fine.
Here bro:
These are staggered 18x8 front et ( offset) 34mm wheel with 12mm hub centric wheel spacer added on 225/40/18
And 18x8.5 rear et (offset )37mm wheel with 12 mm hub centric wheel spacer added on 235/ 40/18
The 12mm spacers create an effective offset of ET 22mm front and ET 25mm rear
Wheels are style 162 from e90 330i
Car is lowered on h&r sport springs & yellow koni's
Fenders are rolled in the rear
No rubbing issues
1 - 14 of 14 Posts
