1 - 7 of 7 Posts
· Yes...I do think I hate you
yes, you can do stiffer springs or shocks, but then the road feel is absorbed more by the subframe and connection points, possibly a contribution to all the subframe failures we are seeing. I have my KW shocks set at the second stiffest, and i still rub if I hit a significant dip in the road. KW recommends not to set at full stiff...i could raise the car a little, but who wants to do that. lol
· Owner
Discussion Starter · #4 ·
So, stiffer shocks would lessen rub, but at the expense of additional stress on the subframe? If you set your KW's softer, will you rub more?
· Registered
I'm planing on that.
Anybody know some good brands for stiffer springs?
How more stiffer is this compared to OEM sport springs?
Or whatabout OEM non-sport springs?
· Registered
Stiffer shocks and/or springs will help. I had 19x10's in the rear w/a 265/30 and stock suspension. Rubbed a lot before, and was reduced about 50% after the stiffer suspension. Slightly less suspension damping and travel help the cause after the swap. But like Fisch said, it may lead to subframe cracking in the long run (had that happen too). It's a tradeoff.
1 - 7 of 7 Posts
