1 - 2 of 2 Posts
Banned
I tried searching, but no luck. Im sure its discussed before.
I have a 2000 328ci SP.
Will the oem 18's off an m3 fit a non-m 3'er?
What will be required to get them to fit.
Also, reccomended tire size(as the current factory tires are bald)
thanks in advanced
Negative. The rears have too low of an offset to work on the Non-M cars. The fronts will work, so if you can get ahold of four fronts you'd be good to go.
1 - 2 of 2 Posts
