I calculated it the other day, it’s roughly $8.50 usd a gallon in Canada for regular these days 😬I was just up there and glad I remembered to top off just before crossing the border.
Yup.Back in the day I repaired many a BMW "S" engine because of detonation (ping/pre ignition) because of not enough octane.
Then Bosch started using microphones (knock sensors) attached to the engine block. They're tuned to a fairly narrow frequency and constantly listen for the onset of knock. When detected the ignition timing is reduced and fuel maps change accordingly.
As long as the regular fuel you use is a known premium brand, you're fine.
FWIW, my wife's F10 535, we run Top Tier regular on day to day. Zero issues.
One of the oft overlooked reasons for a reduction in octane (Remember "active" octane is not only what's in the tank, but what's inside the combustion chamber) is oil consumption. Introduction of oil vapor into a combustion chamber during the compression stroke will reduce the octane level at the moment.I have seen plenty of M54 engine damage.. burnt pistons and valves (chunks missing), gouged cylinders, warped cylinder heads, etc. but none that I would necessarily blame on regular gas...It's usually something else.
I have always used regular gas in my M54-equipped cars.
You might try the non-ethanol. I find the quality of petrol in the PNW poor. The mpg improvement was bigger in our old e36 318ia.I track every fillup of my cars in an app (E46 325i, E61 535xi) and cannot ever see a mpg difference with premium vs regular. Been tracking for 13 years that I’ve had my E46.
Good tip! My wife drives an F10 535! Great car btw.Back in the day I repaired many a BMW "S" engine because of detonation (ping/pre ignition) because of not enough octane.
I tried that for a while as until the end of 2021 the Premium fuel at all Shell stations in Canada was ethanol free. Still didn't see a difference so went back to regular. Ethanol-free should be roughly 3% more efficient I've been told but I couldn't notice it.You might try the non-ethanol. I find the quality of petrol in the PNW poor. The mpg improvement was bigger in our old e36 318ia.
It takes a tank full or two, and or reboot the ecu. Our xi's ecu took a bit to reboot, especially after the wrath of repairs it got. I've never had good experiences with Shell. I'd also run a bottle or two of techron concentrate or BG through to clean things out.I tried that for a while as until the end of 2021 the Premium fuel at all Shell stations in Canada was ethanol free. Still didn't see a difference so went back to regular. Ethanol-free should be roughly 3% more efficient I've been told but I couldn't notice it.
Same here, I haven't been tracking as long as you have but I did experiment with switching over to 93 non-ethanol for a few tanks here and there. I noticed 1-2 mpg better on a few tanks, and worse on a few others. I normally run 87 octane that has 10% ethanol.I track every fillup of my cars in an app (E46 325i, E61 535xi) and cannot ever see a mpg difference with premium vs regular. Been tracking for 13 years that I’ve had my E46.
