1 - 16 of 16 Posts
name's PHIL
looking to swap out my HIGH BEAM lights, H-7.......came down to these two i guess
PIAA = PLASMA SPARK BLUE
PHILIPS = BLUE VISION
any input from u guys
TIA:thumbup:
can ya spare some change?
PIAA is "whiter" than Phillips. I had both, but the Phillips provide more light on the road and a longer beam. I often drive on back roads with no lighting as I live in suburbs.
Although the PIAA's were real white and bright in front of the car, it sucked for illumination. I had to use my highbeams more often cause I couldn't see too far down a pitch black road. I didn't have this problem with the phillips blue visions, but they are defintely not very white. If you want a white bulb, just between these 2, PIAA is white.
I heard the Sylvannia Silverstar were a lot whiter than the phillips and provide equivalent illumination. Too bad they don't make them H7 sizes :sad:
name's PHIL
Discussion Starter · #4 ·
thx for the comments...........keep em comming........shouldve made this into a poll
orice is also a factor i guess, the PIAA's are about 100 for the pair and the philips are 1/2 that
Banned
phillips provide subtle improvements on whiteness and illumination...while PIAA's colours are fantastic...but as people have said, not much of illumination...if you want white beam, try PIAA's Extreme White range. It's Plasma range are more of a purple/blue light beam rather than illumination purposes..and most of them are illegal...for off road/racing only in Japan they are.:yikes:
I just bought a pair of Phillips blue visions H7. They just increased them to 4000K, compared to previous 3500K. I was told by the tech people where I bought them that they were better then the Sylvanias. So, I went that route.
I went with these because they provide better lighting than the PIAAs. Which is the whole point of upgrading.
Have yet to install....will post pics when i do.
name's PHIL
Discussion Starter · #10 · (Edited)
please dooo, i want to see how much whiter they are with the XENONS turned on
ALSO with all this illumination talk between the two, hows this for a question, Do they both definitely have more illumination than my stock halogen high beams or not, if yes then it really doesnt matter between the two and i'll just go for the more whiter one
IMO, the bluevisions don't really give any advantage over stock halogens in terms of brightness, except for the white look. If you want illumination, try Phillips VisionPlus - those bulbs provide much more illumination than stock or the PIAAs. Just won't get that ricey blue/white effect if that's what you're craving.
Don't quote me on this, but that last time I talked to someone that worked at Phillips, they told me that the Bluevisions were basically their Vision Plus bulbs with a blue filter. This is how they are able to provide a teeny bit more light output than the regular halogens bulbs and still achieve the whiter light.
I haven't seen the "new" BlueVisions, but I decided to go with Vision Plus because I wanted more light output over the bluish effect. I sold my Blue Visions about a week after I tried them 2 years ago.
1 - 16 of 16 Posts
