i added a bazooka 10" sub and bazooka el260 bridged mono amp that feeds it 190 watts rms. when the trunk is open there is plenty of bass for my taste - things buzz and rattle (not that that is good but clearly there is enough bass to do it). in the car however, i can barely tell the difference. i still have the stock HK subs running - could they be cancelling some of the sound waves? i left them running because i cross-overed my sub at about 90Hz and i thought the stock subs would be a lot higher then that. if i disconnected the stock subs there would be a hole in the frequencies from where the deck speakers leave off down to about 90Hz. i played with the gain and bass boost settings which didn't seem to make much of a difference in the car. any ideas? should i try disconencting the stock subs? maybe remove one of them to create more of an opening into the passenger compartment (i don't have the ski-bag option)? its an '01 330i if that makes a difference.
separately, does anyone know if boston pro 6.4s would fit up front? i have a set laying around i am currently not using.
thanks,
marc
thanks,
marc
