1 - 5 of 5 Posts
^_^
Guys, my coolant warning light came up again 3 times today. Where is the coolant box located? Is it the white plastic one near the driver's location under the hood?
I've looked at it, it's not that low... it's below MAX but I don't see a minimum level.
Also, is it suppose to need top-ups? Does it mean it's leaking?
I think you're looking at the windshield washer resevoir. My coolant is located near the front right. Check your manual. You can top it off with some distilled water. Make sure the engine is cold when you open up the coolant resevoir! Good luck.
Nick
check behind the drivers side headlight, sort of between the headlight, and grill, let me get a pic for ya
^_^
Discussion Starter · #5 ·
Thanks guys, will check it tomorrow morning. :D
Hopefully some distilled water will do. :p
1 - 5 of 5 Posts
