1 - 1 of 1 Posts
2001 330ci coupe.
Is there a setup anyone can recommend that replaces the OEM wheel bolts with wheel studs and the ability to use a closed lug nut?
Not looking to use wheel spacers or custom wheels. Nothing fancy.
Just want the utility of wheel studs when installing/removing tires. Want the lug nut and stud to work such that there is no extra length of stud poking out (which would require open-ended lug nuts).
What length stud would replicate the OEM stud setup I have on the other cars in the garage - meaning, using a closed lug nut, no wheel spacers, flush fit?
1 - 1 of 1 Posts
