1 - 4 of 4 Posts
I have a set of 18" wheels and I would have like to have 10" wide in the rear but...
Can I use wheel spacer and if I do use them will I have to sacrifice something ?
.com
You want your wheels to be x10 in the rear? Or you already have x10 in the rear?
By spacing your wheels out too far, you have the possibility of acquiring some rubbing issues.
Discussion Starter #3
I have 8 inch in the back but I would like to look a bit bigger and fill the wheel arch a bit better
If you're got an 8" in back now, you could get away with as much as an 8mm spacer probably in back.
You don't sacrifice anything, but you might have to roll the rear fenders slightly.
1 - 4 of 4 Posts
