61 - 78 of 78 Posts
A little over a month ago, I replaced my front wheel bearings/hubs. Considering the cost of OEM bearings and the fact that it was a Friday night, I started shopping around (flame suit on). I thought it would be a great time to review the wheel bearings that are available for our cars. This is not a DIY, but more of a review of the bearings themselves.
OEM - $220 (Edit: $150 - $170 from sponsors)
Of course there is no denying OEM quality. It is certain to fit, certain to work, and certain to provide the same experience that your car did when new. These bearings were quiet and provided very little rolling resistance, although their free-spinning characteristics may have been because of the miles on them, and the absence of grease. I don't have a new OEM bearing to review, but what can you really say? They are OEM and quality. Below is one of my used OEM wheel bearings. Please note the marked groove in the seal, this will be important later.
Timken - $107
I try to support local (Timken is local), but I will be as objective as possible. The Timken bearings appeared high-quality, and are packaged nicely. The bearing and ABS magnet assembly appeared identical to OE, and it came with a nice plastic alignment tool already in the bearing. Installation of the bearing was a breeze. The Timken bearings seem to have slightly more rolling resistance than my used OE bearings. Below is a picture of the Timken bearing, again please note the groove in the seal.
Duralast - $78
They say you get what you pay for, and in this case it rings true. The bearings themselves seemed to be high quality, however the ABS magnet assembly appears to be cut instead of cast, and is quite different than OE. This unit came without an alignment tool. It was difficult to slide the bearing onto the spindle, and the inner race popped out of the bearing in the process. After replacing the inner race and sliding the bearing on, it became obvious that the assembly was rubbing the dust shield. Remember the groove that was in the OE and Timken? It is not present on the Duralast. These bearings are a no-go. Below are pictures of the duralast bearing, and the dust shield that it rubs against.
Conclusion:
OEM is always the best part to put on your car. If you are in a hurry and cannot get OEM at the moment, or if you are thrifty (both were applicable in my case), the Timken bearings can be a viable alternative that will accomplish the same task. I have put about 5000 miles on these Timken bearings so far with no issues. This is in just over a month - I drive a lot. If any issues do arise, I will be sure to update this thread. Hope this helps someone.
Top_bunk I just purchased one wheel bearing from autozone timken ( brand ) and this is what was in the Bx .
Lens Cameras & optics Camera lens Camera accessory Red
Orange Text Font
Photography
Bearing Auto part Wheel
It says koyo!
Am I good with these or No?
Anything in a duralast box from autozone is garbage. They're all shit parts. The only thing good they have is those timken bearings which are actually Koyo, F A G, or SKF. But those are all good. Even their strut/shocks they carry suck. Gabriel and KYB which are bullshit. Sure they can order bilstein and Sachs, but they don't carry shit otherwise. Seriously though, autozone sucks. I try to only go to O'reillys if I have to go to a parts store for something. I've worked at both places as a manager and I can tell you that O'reillys for a fact has better parts. Both stores house brands really aren't that good, but out of the two, O'reilly is better. Plus, O'reilly carries a lot of different brands of products.!Autozone literally almost only has they're shit duralast brand.
So I went to get the other front wheel bearing I needed from a different autozone & to my surprise they had a OEM F.A.G one in stock . Cost 96$ with tax
So I got them installed for $150 but my car is still making the grinding , moaning , groaning , howling sound . . Is it my rear bearings that are making the sound . To me it sounds like it's coming from the front still. Now my car is shaking at 40-50 mph which it wasn't doing prior to install.
E46 F10 W204 W212
Strangely I don't see the Timken front bearings on the AutoZone website anymore. They now have "Moog", which they didn't have before, but I don't know if those are any good. I know the in-house Duralast is garbage based on reports here.
61 - 78 of 78 Posts
