1 - 20 of 25 Posts
TheOnlyConstantIsChange
DSC is not under the temp gauge. Its the warning light to check your brake pads. This could have easily been found in your owners manual. Sometimes I wonder why they even put them in the car.
Banned
Discussion Starter · #6 ·
your one funny guy. thanx for ur reply.
yea i dont have the manual :lmao:
but brake pads. hmm why tho?? i maen inspection 2 is on thursday and im running in the - numbrs now . could that also be part of it?
Yoyu should download the owners manual from BMWusa.com for this sort of situations you never know when you might need it out on the road :thumbup:
Banned
Discussion Starter · #9 ·
thanx but the dealer has mine :(:(.. they took it when my car was in the shop. dont know why.. i guess they were scared for the bodyshop people to steal it. and i forgot to take it back. but i got an apointment on thursday, so i ll get it by then
sheefo2k said:
so is it REALLY important? i mean is it fine to drive around with it.? is it gonna cause more damage? and is this gonna be covered in teh inspection 2.
change ur brake ppads ASAP, don't do the same mistake i did. My light came on, i thought I had like a couple weeks before they would cause any damage, 4 days later, after the light came on, they started making this weird noise, like it was scraping my rotor, turns out they fuked up my rotors.
Banned
Discussion Starter · #12 ·
holly crap dude.
my inspection is on thursday and today is only friday :(:(... the dlear is prob 40 miles away.
hmmm i m screwed dude
inspection is a pain btw
they gonna do all this
Undercarriage
Change oil and oil filter while engine is at operating temperature.
We recommend BMW High Performance 5W-30 Synthetic oil, p/n 07 51 0 017 866
Check transmission for leaks.
Check rear axle for leaks.
Half shafts: Check for leaks at flexible boots.
Visually check fuel tank, lines and connections for leaks.
Check condition, positioning, and mounting of exhaust system. Examine for leaks.
Check power steering system for leaks. Check p/s fluid level; add fluid if necessary.
Check overall thickness of front and rear disc brake pads using special tool. Record results. If replacement is necessary*:
Examine brake disc surfaces. Clean brake pad contact points in calipers. Grease wheel centering hubs. Check thickness of parking brake linings only when replacing rear pads. Record results.
Check brake and clutch system connections and lines for leaks, damage, and incorrect positioning.
Check steering for absence of play, condition of suspension track rods, front axle joints, steering linkage and joint disc.
Check parking brake actuation. Adjust if necessary.
Check all tire pressures (including spare - except M3, M5, Z8 and Alpina). Correct if necessary. Check condition of tires (outer surfaces [left/right]), tread wear and pattern; in case of uneven tread wear readjust wheel alignment if requested.*
Note:If requested rotate all four road wheels as instructed and rebalance.*
Inspect entire body according to terms of rust perforation limited warranty (must be performed at least every two years).
Engine Compartment
Read out diagnostic system.
Check engine cooling system/heater hose connections for leaks. Check coolant level and antifreeze protection level; add coolant if necessary.
Note: Coolant must be replaced every 4 years (time interval begins from vehicle's production date).
Check level of brake and clutch fluid in reservoir. Add fluid if required.
Replace brake fluid every 2 years (timing interval begins from vehicle's production date).*
Check windshield washer fluid level and antifreeze protection. Fill up and/or correct if necessary.
Check air conditioner operation.
Replace microfilter.
Note: reduce replacement interval in dusty operating conditions.
Reset Service Indicator.
Replace intake air cleaner element.
Note: Reduce replace interval in dusty operating conditions.
Body/Electrical Equipment
Check battery state-of-charge, and charge if required.*
Check lighting system, i.e., headlights, foglights, parking, back-up, license-plate, interior (including map reading lights), glove box, flashlight, illuminated make-up mirrors, luggage compartment lights.
Check instrument panel and dashboard illumination.
Check all warning/indicator lights, check control.
Check turn signals, hazard warning flashers, brake lights, horns, headlight dimmer/flasher switch.
Check wipers and washer system(s);wiper blades, washer jet positions.
Check condition and function of safety belts.
Recharge or replace batteries for remote controls in all vehicle master keys.
Check central locking/double lock.
Check operation of all latches.
Check heater/air conditioner blower fan, rear window defogger.
Check rear view mirrors.
Visually examine the SRS airbag units for torn covers, obvious damage or attachment of decals, decorations or accessories.
Activate automatic roll-over protection system (if equipped) via diagnostic link.
Note:First remove hardtop/lower top.
Final Inspection
Road test with check of brakes, suspension, steering, clutch/manual transmission or automatic transmission (except M3, M5, and Z8).
Banned
Discussion Starter · #19 ·
you guys know how much does this thing cost?
my brakes feel really horrible right now... nooo sound nothing. its just takes for ever to brake and i dont wanna slam the pedal...
i read the manual and its saying to not use the brakes hard. and also to send it to the nearest dealer.. hmm how much is this gonna cost now?
the inspection is free. but if any thing happens. i m paying for it :(:(.. this is not good
Banned
the light means minimal brake pad wear. so go get it checked asap.
1 - 20 of 25 Posts
