Hi, so my airbag light is on and I have my MOT coming up mid-August. Car is a RHD 325i with an M54, built in '03.
I bought a cheap k-can cable, installed the Standard Tools and ISTA+. I scanned the codes with ISTA+, had 35! historical errors. Deleted those and was left with 12 error codes, mostly relating to the Multiple Restraint System...
ISTA+ calculated a test plan and the first port of call is to replace the airbag control module. I've located the module and ordered a replacement, however I keep seeing that a new module will probably need to be coded to my car.
So here's my question(s), what does coding a module entail? Could it be done with NCS Expert? ISTA-P? Is it a matter of clicking a few buttons or is it closer to actual
Sorry if these are noob questions. I'm just trying to understand the process better and figure out if it can be done at home to save money.
Much thanks.
hello world
coding? Do you need more sophisticated equipment than a k-can? ISTA+ was mentioning an ICOM and 70amp PSU. I'm presuming a PSU would bypass the battery and the airbags?Sorry if these are noob questions. I'm just trying to understand the process better and figure out if it can be done at home to save money.
Much thanks.
