Does anyone know the size for these 2 o rings? I need them for my e46 325xi. If you guys could supply a size or part number and direct me where to get it I would really appreciate it !
Sounds goodGo to www.realOEM.com. Enter the last 7 digits of your VIN number into the search tool. You can then browse for the parts specific to your car. In the cooling section, you will find both the part number and the O Ring size.
Thank you !!!17111711987
14.5x 2.5
Familiarize yourself with RealOEM though, it's a lifesaver!Thank you !!!
I can confirm this. And that o-ring has been on my coupe for 10 years and 115k miles.If you’re desperate enough and have a Harbor Freight around. They have a $9.99 Viton oring kit that includes that exact size. I replaced those exact orings with the HF kit.
OP, since yuo obviously have an auto trans, that is the same o-ring used for the ET holder to radiator attachment at the bottom drivers side of the radiator.Does anyone know the size for these 2 o rings? I need them for my e46 325xi. If you guys could supply a size or part number and direct me where to get it I would really appreciate it ! View attachment 932561
