For that shot he does. I don't think I could get the same result on the previous shot with curves. If you can I'd love an explanation.
http://www.flickr.com/photos/jojo2fast/4947062119/in/set-72157624634705620/Got some more messages about the processing on this set so here's a couple before and afters. Just curves was used.
I've been getting a lot of messages/comments again about processing for this set. I don't think people believe me when I say I spend a minute on one picture and don't do all that much to begin with. So hopefully this proves that lol.
I don't use S-curves but it does give a slightly similar look.
Why?Do this for each color channel independently. As in make another curves layer, dont just switch the channel in the adjustment box.
What is the exact effect that you're referring to?
Bingo :thumbsup:Using curves for each color channel allows you to tweak each color independently... You can acheive similar looks by using curves on the entire RGB spectrum, and it's easier, but you can't fine tune the saturations and such...
The color and warmth.What is the exact effect that you're referring to?
The sharpness/contrast?
The bokeh?
The sun flare?
The saturation?
I do that too and I have a hard time believing one stop is all it takes to achieve that look. Maybe it is the contre jour. I'll try that.Fast lens, proper lighting and not overdoing post...
And by proper lighting I mean shooting in golden light (just as the sun is rising or setting). You can look at his exif data and see that most of the photos you refer to as warm are taken early in the morning or just around golden hour.
Perfect. Thanks! I will try it in Argentina later this week. ;-)A photo like this, the effect I mean, is the result of shooting into the sun obviously. The haze you occasionally get. If he wanted to fix it, he could just make a black solid color fill and set the blending mode to hard mix at say 10%.
http://www.flickr.com/photos/jojo2fast/5021383341
The reverse of that, intentionally putting the haze there is just a mix of solid color fills set at a low blending percent. You just need to know the right colors to use and what blend mode to use. A photo like this with a vanilla colored haze
http://www.flickr.com/photos/jojo2fast/5032152445
or this one with a warmer haze
http://www.flickr.com/photos/jojo2fast/5088027946
Take the picture during the Golden Hour.The color and warmth.
