1 - 8 of 8 Posts
# 6 is your adjuster unit for your Intake Manifold System. Does the "noise" sound like an air leak?
If it is, it might be as simple as a worn O-ring (18), rubber mount (8), or the rubber grommet for your idle valve (10).
where in gods name did you find that diagram i tried everything haha. guess its good to have thousands of dif memebers all lookin at once!
For complete diagrams...
www.realoem.com
Not sure, there alot of loose parts that may be causing the noise. Without hearing or seeing it, it's hard to tell.
Sorry here's the RIGHT diagram for your car. I have the 328i bookmarked.
less moving parts...
Do a search for "DISA", you should find several references to that part.
it may be this part below that intake manifold. I just replaced that piece in my 2000 328i because it was whistling from a tear in the rubber.. hard to get to but only a $16.00 piece. plus you can clean your idle control valve while you've got all that stuff apart.
1 - 8 of 8 Posts
