What is the best tune for a E46 M3 SMG?
1 reading
9.4K views 11 replies 5 participants last post by  spearmin
#1 · (Edited)
I’ve been looking at Build Journal, just haven’t pulled the trigger yet. Does anyone have any other recommendations or maybe info that would make me choose a different tune? Or am I overthinking this?
Link to the tune I’m looking at BuildJournal tune page
Current Mods are Injen Intake, BC coil overs, catless headers, full exhaust system from headers back.
Thanks in advance for any help or comments
#3 · (Edited)
I disagree. I went with TTFS and it was a very noticeable difference. Hassan at HTE Performance offers good engine tuning as well.
Beings you have an SMG you need to get the CSL SMG Tune. I originally got TTFS SMG tune and also flashed the CSL SMG tune using Martyn’s MSS5X Binary Tool. What a huge difference these make! It’s a must for SMG owners.
TTFS: BMW E46 M3 Tuning | Tuning Tech FS
HTE Performance: HTE Performance. E46 Tuning
Get Martyn’s MSS5X Binary Tool and flash the SMG CSL Rev Matching / Inertia update along with the 255 CSL Software update. You will love the way the SMG shifts afterwards.
MSS52 / MSS54 / MSS54HP Binary Modification Tool
https://www.ecuworx.co.uk/2015/05/18/mss54xbinarymodificationtool/
UPDATING THE SMG ECU TO RUN CSL ‘255’ SOFTWARE
ECUWorx Flashing Cables – E46 M3 / E39 M5
https://www.ecuworx.co.uk/product/ecuworx-flashing-cable-for-e46-m3-e39-m5/
Included with the cable is the latest ECUWorx Binary Modification Tool, BMWFlash, MSSFlasher, the BMW Toolset and the additional E46 daten files.
  • Like
  • Helpful
Reactions: guayo42 and cmagz
#4 ·
255 CSL SMG Software- "BMW E46 SP Daten Files in Post #20"
Thank you! I will look into all of this! Should these be done in any specific order?
#7 ·
  • Like
Reactions: cmagz
#8 ·
Martyn’s Tool Features:
– 155MPH Limiter removal
– SMG Style Shift lights on 6 Speed Manual cars (E46 Only)
– Sport button memory (remembers last setting after shutting off the vehicle).
– Dyno limit removal
– Rev limiter adjustment
– CSL SMG Shift / Rev matching + Inertia fix (E46 Only)
– Disable secondary air pump from running on cold start
– Enable burble and pop on over run / lift off (Childish but some love it)
– Disable fault code / check engine light for physical removal of the secondary air pump
– Disable fault codes / check engine light for cat deletes
– Disable fault codes for rear O2 removal
– EWS delete
– Comfort throttle map adjustment
– Sport throttle map adjustment
– Warm up light changes
– Transmission Swap (Manual to SMG and visa versa)
– SMG Final Drive Swap
– CSL Intake Flap Delete
– Cruise control enable (CSL / CSL Clone only)
– IAT Temp Sensor swap/re-scale
– MAP Sensor Swap/re-scale
– E39 M5 Servotronic Adjustment (Sport and Comfort)
– AlphaN enable/MAF Delete (E46 only)
– Disable cat protection (disables enrichment under high EGTs)
– Disable EGT Monitoring
– CSL Intake Flap opening control (CSL / CSL Clone only)
– Checksum correction
6MT Shift Lights
This feature allows SMG style shift lights to operate on manual E46 M3s. The options available are as follows:
[emoji830]Disabled
[emoji830]Enabled (Always active)
[emoji830]Enabled with Sport Mode
The options above are self explanatory.
Sport Memory
This feature allows control over how the ‘sport’ button behaves. The options available are as follows:
[emoji830]Sport mode via button press (default)
[emoji830]Sport mode always on
[emoji830]Comfort mode always on
[emoji830]Enabled upon DSC button press (DSC off)
[emoji830]Sport mode memory
The above options are self explanatory, most people select ‘sport mode memory’ allowing the car to remember the last setting when the car was turned off.
Dyno Rev Limit
This feature removes the static rev limit of 6300 RPM that interferes with correct Dyno operation. It is recommended that you set this at the same value as the ‘in gear’ rev limit mentioned below.
Rev Limit (All Gears + N)
The Rev Limit is fairly self explanatory, the limit can be adjusted dependent on the end users requirements. The stock rev limit of an E46 M3 is 8000RPM. It is not advised to go beyond 8200RPM.
Transmission Swap
If you have a chassis swapped car or want to change your transmission then you can swap between SMG and Manual. If you swap from SMG to Manual, the DTCs for SMG parts will be disabled automatically.
If you have an SMG equipped car and wish to change your final drive (differential ratio) you can change the ratio expected by the ECU to one of the following options, this will allow correct shifting when in ‘auto’:
[emoji830]3.62:1 Ratio (Stock E46 M3)
[emoji830]3.91:1 Ratio
[emoji830]4.10:1 Ratio
IAT Sensor Re-scale
IAT sensor rescaling allows the use of alternative Intake Air Temperature sensors, this is useful for those wishing to run a CSL style airbox without having to use a stock CSL IAT sensor.
MAP Sensor Swap (CSL Only)
This allows use of a non BMW MAP sensor on CSL ECU software. A 1 Bar GM sensor is a good alternative.
Cat Protection (EGT)
Allows you to modify the temperature at which EGT (Exhaust Gas Temperature) ‘Cat’ protection kicks in.
155 MPH Limiter Removal
Ticking this option will remove the factory imposed speed limiter of 155MPH or 258KPH.
Burble / Pop On Lift Off
This option will alter the fuel cut delay and minimum ignition to allow rally style pops and bangs. Due to the nature of this change, it is not recommended for use with cars running cats.
CSL SMG Shifting / Rev Matching
This is one of the best modifications you can make to your SMG equipped M3. The feature will update the ECU to use the same shifting and rev matching parameters as that of the M3 CSL. After applying this option, the car will shift gears with increased accuracy and also rev match on down changes, just like in the M3 CSL.
SMG Inertia Update
This option increases the clamping force of the clutch reducing SMG ‘clutch slur’. It is recommended when using the CSL SMG Shifting and Rev Matching option.
Disable SAP / Cat Heating Sequence-
This option will disable the secondary air pump that performs ‘cat heating’.
Disable SAP DTCs
(SAP hardware removed)-
This option should be selected when the secondary air pump has been physically removed from the vehicle. Selecting this option will prevent the check engine light illuminating.
Disable CSL intake flap DTCs
Selecting this option is recommended if you are running an M3 CSL ECU and wish to ‘delete’ or remove the intake flap and motor. Selecting this option will prevent the check engine light illuminating.
Enable Cruise control
(CSL / CSL Clones Only)-
This option will allow CSL converted ECUs to activate cruise control.
Enable Alpha N / MAF Delete
(Experimental)
This option is for those who wish to drive to their tuner with a carbon airbox fitted, a custom Alpha N tune is still required.
EWS Delete + EWS Tampering DTC Delete
Enables the vehicle to run with a foreign ECU, useful for ECU swaps or motor swaps.
Disable Cat Protection (Disables enrichment)
For those running catless or decats, disabling cat protection / enrichment enables finer control of the fueling without the ECU trying to protect the catalytic converters.
Disables exhaust gas temperature monitoring. If you have ‘headers’ without an option for an EGT sensor, please use this option to prevent EGT control and associated check engine lights / DTCs.
Disable Cat Efficiency DTCs
Allows a user to run catless or decats whilst still keeping the rear / secondary lambda probes in place.
Disable Rear O2 DTCs (Hardware Removed)-
Allows complete removal of the secondary O2 / lambda sensors, useful when running after-market headers and decats.
Suppresses the DTCs associated with full CSL software when a flap is not fitted.
Disable ‘151’ DTC
(For CSL Clones)-
Suppresses the ‘151’ DTC that is flagged when full CSL software is flashed to converted MSS54Hp ECUs.
Disable ‘105’ DTC for Motorsport Thermostats
Suppresses the ‘105’ DTC flagged when running a Motorsport thermostat.
Warm Up Light Recalibration
This option allows finite control of the ‘warm up’ lights that surround the rev counter of the E46 M3 and E39 M5.
Performance Tuning by Evolve Automotive /www.evolveautomotive.com/> (E46 M3 Only)
Allows application of a ‘euro’ tune to the E46 M3. The tune has been developed by Evolve Automotive and is tried and tested throughout the world. Gains expected are 14-25BHP and increased driveability.
CSL Intake Flap Control
(CSL Only)-
Allows control of at what RPM the intake flap opens and closes when in ‘sport’ and ‘comfort’ modes on the M3 CSL.
Throttle Adjustment
(Comfort / Sport)-
Allows finite control over the mapping of the electronic throttle vs accelerator pedal in both ‘comfort’ and ‘sport’ modes.
(E39 M5 Only)-
Allows finite control over the weighting of the servotronic steering found in the E39 M5. The weight or assistance of the steering can be changed based on the current speed of the vehicle.
Exhaust Backfire by BuildJournal
Allows / enables backfires / pop / bangs as designed by the guys over at BuildJournal. This setting must not be enabled if you have cats and is separate to the ECUWorx pops and bangs feature.
"Valet Mode" done through throttle input in comfort mode. Basically comfort mode is Valet Mode.
Simple and works in the real life. Just enough to be safe in traffic and merging. Of course there is still no speed limiter doing it this method. But 0-100 at a turtle's pace may deter some valet guys.
MSS52 / MSS54 BINARY MODIFICATION TOOL
( CSL SMG Shift / Rev matching + Inertia fix )
  • Love
Reactions: cmagz
#10 ·
– EWS delete
6MT Shift Lights
[emoji830]Disabled
Sport Memory
Dyno Rev Limit
Transmission Swap
IAT Sensor Re-scale
SMG Inertia Update
Disable SAP DTCs
(Experimental)
Disable ‘151’ DTC
(For CSL Clones)-
(CSL Only)-
Throttle Adjustment
(Comfort / Sport)-
(E39 M5 Only)-
Dang great info! Thank you for taking the time to do that.
#11 ·
Hi, just learned of these SMG tunes and have a Dinan '03 M3 with their ECU tune. I once had the ECU flashed back to stock by a dealer mistakenly who didn't realize I had the Dinan ECU and the car drove terribly. Does a SMG tune work independently of the ECU tune, or would any SMG tune affect the original Dinan ECU tune? Thanks!
