1 - 13 of 13 Posts
****** User
ok i was driving today and hit a little bump and i heard a crack or something and i pulled over. i noticed the left side of the car is a little lower. did the shock possibly blow ? and then i noticed the car is shaking a little not a lot but it idles a little rougher and exhaust sounds a bit different. whats wrong with the car?!?!
Banned
you dont want to know. what kind of suspension you running? oem? aftermarket? race or sport?
Lying, drunken cheat
Race springs with stock dampers?? You probably answered your own question right there. Unless you damaged the strut somehow.
Banned
ya if your car on flat ground looks like the post above mine:
it's probably your shock. :rolleyes:
I'm hot 'cause I'm fly
press down on the front of your car. Does it bounce more than usual? I think the general rule is the car should only bounce like 2 or 2.5 times before stopping...or maybe its 1.5 :blink:. I dunno how well that method will work with race springs tho.
i guess my point is that if it is much bouncier than normal than you blew a shock
1 - 13 of 13 Posts
