Well, it looks like it has the kind of o ring you can replace (which I would do) so that's a plus. The pin is in place so that's another plus. (Give it a tug anyway). All you have to do is test the diaphragm and the solenoid to see if they're ok (see below). If it all checks out then buy it.View attachment 919199
Would you guys buy this DISA for 20$ and put it in your BMW if it was needed? It came from an XI. Looks like the gaskets might be bad. Any opinions?
It is true the 2.5L has a smaller shorter disa...they are not interchangeable.Well, it looks like it has the kind of o ring you can replace (which I would do) so that's a plus. The pin is in place so that's another plus. (Give it a tug anyway). All you have to do is test the diaphragm and the solenoid to see if they're ok (see below). If it all checks out then buy it.
BTW I believe teh 3.0L and 2.5L DISAs are different so make sure it's the right one for your car.
Awesome thank you, it says it's a 2.5 XI Dish and It's going into a 2.5 iWell, it looks like it has the kind of o ring you can replace (which I would do) so that's a plus. The pin is in place so that's another plus. (Give it a tug anyway). All you have to do is test the diaphragm and the solenoid to see if they're ok (see below). If it all checks out then buy it.
