Hello,
I'm trying to narrow down my cylinder 2 misfire before I start taking my motor apart. It only happens on frequent cold starts (I'm in California. so it's not cold) but goes away if I restart the car. It drives fine. But the CEL will come on during idle "cyl 2 misfire with fuel cutoff". It resolves itself after a quick restart. If I let the car sit for 4 hours and start it again if also misfire cyl 2 but goes away after a restart and drives fine
So far I changed,
Sparkplugs
Coils
Fuel pump
Replaced vacuum lines
Fuel filter
Intake boots
I've read the CCV, ICV, DISA, and oil separator hose can cause misfires but that's on multiple cylinders right?
I notice the vaccum lines on the Intake boot were the F connector is look like they need changing but why would that only affect one cyl?
What can cause a misfire on only one cylinder? I learned plugs/coils/injectors or mechanical failure of the cyl but I doubt that because the car does it randomly when it's cold. Im doing a compression test anyways.
The only other options I have is to illegal pass smog and live with the misfire because I can afford wasting more money
So far I changed,
Sparkplugs
Coils
Fuel pump
Fuel filter
Intake boots
