1 - 13 of 13 Posts
My setup has 2 Alpine amps, a MRV-f450 and a MRV-T320, do I need a cap to power up those 2 amps? What does it do?
booo for body roll.
cap gives it power for those really bassy hits where alot of energy is needed and doesnt drain ur battery system
A cap has NOTHING to do with your headlights dimming, and WILL NOT resolve that problem at all. As stated above, a cap is supposed to be used for deep bass drops, where the amp would normally clip, and hold out the entire note. Without a cap, the regular car battery can not supply power fast enough to the amp to accomplish this.
Do you need it? Depends on how tuned your ear is.....will most people notice the difference between a system with caps and without.....NO!
A cap is good if your amps require sometime a lot of current from the battery. The battery cannot deliver that current in a very short time, so the cap jumps in. Otherwise, with normal current draws, the cap is not even working.
Discussion Starter #8
Does it increases the current from 12 volts to 14.4 volts??
no munich, the battery voltage is normally 14.4 when the car is running, and appr 12.6 when the engine is off.
But current is another electrical measure which is drawn from a battery. Whenever this draw needs to be done real fast, the cap comes in and delivers the current. Immediately after the cap has delivered the current, it recharges very quickly again in order to be ready for the next demand. When no demand is coming, the cap stays 'idle' . Quite difficult to explain, but I hope you get the picture.
Hans
I thought the rule of thumb was that you don't need a cap unless your system and/or the power going to your subs is more than a 1,000W?
That's similar to what I remember. One farad for each 1kw.
Most systems will not need a cap.
1 - 13 of 13 Posts
