1 - 20 of 22 Posts
2005 BMW 330i
46mm (right?) for wheel hub nut
That would be a 32 for the fan. I suppose one could use a 36 for the filter, but why.
I'd pay to see someone get a 46mm "wrench" onto a wheel hub but.
OP - my advice is to get a set of (preferably) 6-point metric box-end wrenches up to 21 or 22mm, and then get one-off sockets/wrenches for specific needs (oil filter, fan clutch, etc.) as needed.
a ratcheting set of metric wrenches is also nice as a second purchase, but you don't need to go up to 22mm
BTW - If you or anyone else is building a long-term tool set, a set of Metrinch sockets (combo metric/sae) is worth its weight in gold when dealing with rusty, rounded, or stripped bolts .
I bought a 6 point socket for the filter cap. Cap was almost pristine when I sold the car. No, I am not OCD, just finicky. Hrrrumpf.
36mm for rear hub nuts- 32 in front? I forgets.
I 3d printed a socket for the oil filter cap- but then, forgot, and left
it sitting on there when the engine was hot. That didn't go so well.
Now I use the 3/4" drive socket and breaker bar.
t
overkill is never enough.
Naw, he's talking 25 Nm for the torque on the cap.
Which is a silly German confabulation, because the cap
just needs to be seated, not torqued. The o- ring does all the work, on that one.
t
calibrated torque hands.
t
You're not wrong, however I prefer to seat it.
I can't tell you how many times we see Chinese oil filters with undersized O Rings that leak.
Nevermind holding the cap in place.
t
Yes on the Nm. But it should have been ft lbs. Now corrected.
But if there is a torque spec then it should be applied. It's just good practice. In this case it's only plastic
so advisable imo.
There's a specification for everything!!!!
t
gootentight
Stripped threads are better than no threads. o_O
1 - 20 of 22 Posts
