1 - 1 of 1 Posts
I purchased some HP EVO's 18-8's w/ 235-40's (makes the car looks so much better) :thumbup: when I installed them I had a slight shake in the steering wheel, (a very irritating problem as I travel 70 miles one way to work :banghead: ) they did not come with the hubcentric rings, so I called back and got them, took about 3 1/2 weeks. I installed one on the drivers side no prob, then went to install the other on the passenger side and found the ring to be to big, it fit the hub but was slightly larger on the rim, tried several ways to make it fit but in the end just left it off (will contact the company Monday) weird part was after putting rims back on I test drove it and steering shake was gone!!!!! :woot: just letting ya all know hub rings can make the difference, if you have this prob, even just one (wtfita)
1 - 1 of 1 Posts
