is the walbro really much better than a stock M3 pump? how much volume does it flow at 5 bar? from what I've seen, at higher pressure the volume drops off with these cheaper pumps.
I was going to use a bosch 040 but it's huge, and doesn't fit through the tank hole.
Depends on which one you buy but the gss342 will support 575 hp at 65psi that's a base of 45lbs with 20lbs of boost if you can make it with less rail pressure, it will support more power. I have 2 running a 2jz through a th400 at 800rwhp so it should be at least 1000 hp at the crank.
1 - 3 of 3 Posts
A forum community dedicated to BMW E46, E90, and F30 owners and enthusiasts. Come join the discussion about M performance, turbo kits, engine swaps, builds, modifications, classifieds, troubleshooting, maintenance, and more!
