I want to pass along some recent experiences with Wahler thermostats. Wahler thermostats have been well-regarded as a good replacement for E46. I have 2 E46 and I replaced the thermostat on E46#1 with a Wahler in Sept 2021 shortly after purchasing the car as preventative maintenance since I can see caked coolant on the bottom side of the thermostat. In addition, I replaced the thermostat on E46#2 with a Wahler in June 2022 as preventative maintenance since I was replacing a leaky water pump.
In Nov 2022, about 5 months after I installed the Wahler on E46#2, I noticed that coolant was leaking from the bottom of the thermostat. Upon investigation, I determined the thermostat wasn't sealing properly against the engine block. I replaced it with FCP's lifetime warranty with another Wahler. I installed the replacement and so far it's fine. It cost me a couple of hours of time, new coolant, and return shipping to FCP.
After this, I naturally went to check on E46#1 and I noticed that coolant has been leaking for a while from the bottom of the thermostat, just like my E46#2. The leak was small enough that coolant only got as far as the bottom splash guard and around the front of the engine. Coolant never got on the ground so I never noticed. The leak was small enough that I never lost significant coolant. Upon investigation, once again I determined the thermostat wasn't sealing properly against the engine block. Now I was alarmed that both Wahlers have failed the same way. This time with my E46#1, I didn't want to just install another Wahler in case there was an inherent defect such that I would have to replace it over and over again every 6 months.
Since the leak was a bad seal against the engine block, I elected to buy replacement thermostat gaskets instead of doing a warranty replacement with FCP Euro. I purchased a BMW one (~$10) and an Elring (~$6). I removed the gasket from the leaking Wahler thermostat from E46#1 and compared it to the replacement gaskets I purchased. The leaking one is on the left and the new BMW one is on the right. They look almost the same, but when I put a caliper to them, there is what I measured:
Old leaking one from Wahler - 0.210" (width)
New BMW one - 0.235" (width)
New Elring one - 0.232" (width)
So there's a (possibly significant) difference between the Wahler gasket vs. BMW and Elring. It should be noted that the leaking Wahler gasket had been used (compressed) for ~12-14 months so that may affect its physical measurement.
Rather than returning the Wahler to FCP Euro for a warranty replacement, I elected to simply replace the gasket with a BMW one. It's been a couple of days and so far so good. This cost me a couple of hours of time, new coolant, and ~$10 for the new gasket.
I hope this data helps some of you to draw your own conclusion.
