1 - 2 of 2 Posts
european auto source
Up for sale is our VF570 Supercharger from our project Z4M. Kit was installed shortly before MFest 2012 in April and has approximately 3500mi on the system. Kit comes complete with all Hardware, Injectors, & Cooling system.
Supercharger system has been meticulously inspected and cleared for removal. Vortech unit will have oil changed before purchasing, along with additional oil for next fluid change.
Retail is $9,900 on the VF570 systems, we are selling for $7000 shipped within US. Installation and dyno services are also available on site. System will fit 2006-208 Z4M Roadsters and Coupe versions.
The Software will be required from VF Engineering at an additional cost. Kit can be off vehicle and ready to ship within 3 days of cleared payment.
Underhood
VF570 Supercharger System Components
- Vortech V3-SQ SuperQuiet SC trim supercharger (no oil lines)
- 8.5-9.0 psi supercharger pulley setup
- MAF upgrade conversion
- 1 year unlimited mileage limited product warranty
- Replacement cast intake manifold
- VF CNC machined 6061 aluminum bracket system
- OEM BMW idler pulleys
- Stage 1 OEM High flow spray pattern matched fuel injectors
- VF Custom molded polypropylene ducting
- VF Custom tuned cast supercharger intake
- High flow Greddy Type R overrun bypass valve system
- Custom crank case ventilation system
- 4 ply silicon couplers with OEM screw clamps
- Replacement OEM serpentine belt
- K&N induction filter with cold air intake
- Precision Made in the USA
- Bypass valve spring upgrade
- Slide-in air/water heat exchanger for intake manifold
- Bosch water pump activated by key power relay
- VF water reservoir system
- OEM front center water radiator with OEM hangers and water lines
More info on the VF750 systems can be found on our website here: https://www.europeanautosource.com/product/vf-engineering-supercharger-system-e85-z4m
Priced to sell quickly just in time for race season. Questions and comments can be answered by calling 714.369.8524 or via email for quickest reply.
1 - 2 of 2 Posts
